Author Topic: Mini fire extinguishers  (Read 1818 times)
Offline Scout63
« on: November 04, 2020, 08:57:27 PM »
After my Commando caught fire in the air cleaner the other week I purchased a couple of mini extinguishers.  I’ll try to figure out a good mounting system for each bike or maybe just get a few more and keep one in each backpack and set of bags. This is the second fire in under a year so it’s either give up vintage bikes or take the extinguishers seriously.
Ben Zehnder - Orleans, MA USA
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Mini fire extinguishers
« Reply #1 on: November 04, 2020, 09:38:47 PM »
Perhaps a tractor manual canister or, if you want to show it off, using one of these...?
Offline lucky phil
« Reply #2 on: November 04, 2020, 10:09:05 PM »
Whats causing the filter fires? backfiring on starting? seems fixing that is the answer not lugging an extinguisher around.
Ciao
Offline moto-uno
« Reply #3 on: November 05, 2020, 12:02:59 AM »
 If you mount it just right , it can look like a nitrous bottle !! Peter
Offline Knuckle Dragger
« Reply #4 on: November 05, 2020, 12:06:05 AM »
Bicycle water bottle cradle/carrier zip-tied to a downtube?
Severus bastardis
Offline Scout63
« Reply #5 on: November 05, 2020, 06:16:03 AM »
Ciao
The Commando backfired very slightly on a cold weather start, then I closed the air slide and it started. After I ran it for about five minutes and shut it down I saw the stock paper filter glowing inside the screen housing. Then it turned into a flame.  I shot a small burst from my garage extinguisher into the air box from each side.
I like to think it was a confluence of factors and not likely to happen again, but carrying a small extinguisher seems wise.  Good mounting suggestions.
Online Perazzimx14
« Reply #6 on: November 05, 2020, 06:43:55 AM »
You'll also have be disciplined and spend a few minutes being a fire watch every time you turn the bike off.
Offline ozarquebus
  • Grand Canyon Pack Rat
  • Riding since 1979
« Reply #7 on: November 05, 2020, 09:30:35 AM »
I tried to find a truly small fire extinguisher a few years back with no luck. Finally went to an actual safety equipment store and inquired. They told me a minimal size "fire" was actually defined by federal regulation and a fire extinguisher must be large enough to put out that specified size "fire" to be sold. Therefore a truly mini fire extinguisher is not even manufactured in US. Smallest is about 1 Liter size. There are some very small antique brass pump types around you could fill with soda water.
 Now, however it looks like they have gotten around the regulation by calling them 'fire suppressors' and here is a 16 oz example.
« Last Edit: November 05, 2020, 09:37:36 AM by ozarquebus »
 Convert Hangar Queen
Offline lucky phil
« Reply #8 on: November 05, 2020, 03:56:55 PM »
Is the ignition system stock or is it fitted with an aftermarket electronic unit? I was reading recently where a LOT of the aftermarket electronic systems are still live even with the ignition system off which has caused fires on shut down. You turn the ignition off and the engine gives a little cough back into the intake but the electronic system is still active and ignites the fuel and a fire results. just a thought. Seems crazy to need to carry an extinguisher around with you and remember to do a fire check every time you stop the bike.
Ciao
Offline reidy
« Reply #9 on: November 07, 2020, 01:16:44 AM »
You could always invest in a couple of Australian mini fire extinguishers. Just give them a good shake and crack them open. Puts out a good spray of foam. They are quite reasonably priced and you can get them in a single, six or twenty four pack. I have seen some in 30 packs as well.  :boozing:
Offline lucky phil
« Reply #10 on: November 07, 2020, 01:28:15 AM »
True, didn't think of that :laugh:
Ciao
Offline Bobic69
« Reply #11 on: November 07, 2020, 05:48:42 AM »
I've seen adventure bike riders attach 4" PVC plumber's pipe with screw cap ends for storage. Painted black they're pretty discreet. I reckon a small extinguisher would fit nicely in one of those.
Bellagio
Offline Joliet Jim
  • Justus Esto, Et Non Metue
« Reply #12 on: November 07, 2020, 08:07:21 AM »
I could have used one yesterday when the Centauro caught fire (briefly), and years ago when the Trident had an electrical fire while i was on it. Nothing like flames in your crotch right by the gas taps to make you want to dismount really quickly.
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Just memories
The Psycho Chicken
The Fire Demon
Thumper
