Author Topic: Rusty ABS Ring  (Read 1073 times)
Offline greer
Rusty ABS Ring
« on: November 05, 2020, 08:20:21 AM »
The ABS ring on my front wheel is rusty as all get out, any reason I shouldn't sand and paint the thing?  I wouldn't want to do anything that might cause the sensor not to sense, if that makes sense :shocked:.  Thanks!
Sarah
Offline Perazzimx14
Re: Rusty ABS Ring
« Reply #1 on: November 05, 2020, 08:35:55 AM »
Sarah
Sand, wire brush, media blast and/or chemically strip it then paint with good quality caliper paint.
Offline greer
Re: Rusty ABS Ring
« Reply #2 on: November 05, 2020, 09:19:39 AM »
Thank you!
Sarah
Offline Mike Tashjian
Re: Rusty ABS Ring
« Reply #3 on: November 06, 2020, 06:33:37 AM »
One thing to remember with ABS rings is the gap. Should it get too big the sensor will not work properly.  I can't imagine sanding will change it enough to worry about.  One of my bikes has a spacer which adjusts the gap so that it is held in the right spot.
