The V7 I'm working on has a Twin-filament Bulb in the rear Light Unit, and the correct Bulb Holder, but only has two Wires to it (Black & Yellow).Does it rely on the Light Bracket & Mudguard for the Earth return?Black Wire goes to the rear Brake Switch, Yellow goes to the middle Tab on the Box behind the Battery (Voltage Regulator?).
Nice job!I do like Wiring, maybe I'm odd, but I find it quite 'therapeutic' (as long as everything's going OK).If it were mine, I'd most likely rip it all out and do similar you yours.Nice to see the Fuse 'box' made to look like the original.I've just recently retired from my job as an Aircraft Engineer, I think I got my love of neatly laid-out Wiring from there.
