Author Topic: Rocker shaft oiling? (early square barrels)  (Read 1693 times)
Offline SED
« on: November 29, 2020, 12:17:00 PM »
Redid the valves on the LMIII and was checking oil flow to the rockers and was surprised to see oil coming out from the split washer under the  rocker pin lock bolt.  Is it designed this way?  It doesn't seem right, but everything is original to the bike.
Thanks!
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline moto-uno
Re: Rocker shaft oiling? (early square barrels)
« Reply #1 on: November 29, 2020, 01:09:34 PM »
  The lube goes through the shaft to the rocker arm bushings and from there along the shaft to the openings offering
the least resistance to oil flow ( the opposite side of the rocker is held somewhat firmly against the rocker arm support
by that spring and hence offers greater resistance to the oil exiting there ) , hope that is clear enough . Peter
Offline SED
« Reply #2 on: November 29, 2020, 01:24:18 PM »
Thanks Peter, but it is also coming out from under the bolt heads.  It seems like there should be a sealing washer.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline SED
« Reply #3 on: November 29, 2020, 03:58:41 PM »
Is it "oh they all do that"?
Or no one's ever checked.   :evil:
I didn't look for oil from between the pin and carrier plate, but it's probably leaking there too.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #4 on: November 29, 2020, 09:47:16 PM »
If you were to measure the oil pressure and it's up around 60 then you can forget about any leaks you see.
Offline SED
« Reply #5 on: November 29, 2020, 10:27:13 PM »
Good point, but I'm guessing it drops well below 60 at hot idle.
And the pins have been rotated (double drilled), but they are not new...
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #6 on: November 30, 2020, 01:03:47 AM »
I can't say that I have ever checked for leakage there. I guess it could happen. None of my bikes have anything other than the bolt and a lock washer. They all have split lock washers, but MAY have had a different style lock washer when new.
The bolt is a specific length. Too short and you risk stripping the hole. Too long and you cut off the oil supply to the rocker. And yes, if the threads are buggered, you can just rotate the shaft. Just make sure all the debris are out of the hole.
Hope this helps,
Offline reidy
« Reply #7 on: November 30, 2020, 01:14:27 AM »
I think the other thing to note is that in some applications it takes surprisingly little oil to provide the required lubrication. For example, a 2 stroke engine with 50 to 1 or 100 to 1 oil ratio. Another is a Briggs and Stratton with splash lubrication. Even the rollers in a motorcycle chain.
Steve
jwinwi
« Reply #8 on: November 30, 2020, 08:08:01 AM »
Would it make any difference if you are using split lock washers or schnorr washers? :popcorn:
Offline Don G
« Reply #9 on: November 30, 2020, 08:51:26 AM »
Put the covers on and forget about it! :thumb: DonG
