Author Topic: V11 Sport 2001, horrible clutch screech  (Read 1707 times)
Offline rich4822
« on: December 12, 2020, 10:56:12 AM »
My V11 Sport has suddenly decided to make a horrible screeching noise as soon as I start to pull it in.
It's been sat for a couple of months ue to totally crap weather here.
Souns fine when let fully out.
Has the release bearing gone bye bye?
Help!
Re: V11 Sport 2001, horrible clutch screech
« Reply #1 on: December 12, 2020, 11:20:17 AM »
That's what it sounds like, throwout bearing shot. Check your trans fluid for proper level when erect. It sits in trans behind the clutch slave cylinder, 3 bolts.
Offline Huzo
« Reply #2 on: December 12, 2020, 12:01:47 PM »
That seems like a strange thing to be concerning yourself with at such a moment... :popcorn:
« Reply #3 on: December 12, 2020, 12:11:59 PM »
To make sure there is oil for bearing otherwise it squeels.
Offline rich4822
« Reply #4 on: December 12, 2020, 12:53:29 PM »
Well it's quite cold here in the UK tonight, but I'll do my best to check the oil level while erect...
On a more serious note, the throwout bearing gets oiled from the gearbox oil, Right?
What's involved in getting the slave cylinder off? What else has to be taken off first...
« Reply #5 on: December 12, 2020, 01:14:11 PM »
Yes, oiled from trans. It is almost center in front of swingarm to the inside of output ujoint. Most likely swingarm removal is easiest on V11 Sport series.
Here's a manual---https://guzzitek.org/atelier/gb/1100/V11_99_03_AtelierMAJ01.pdf
« Last Edit: December 12, 2020, 01:18:28 PM by guzzisteve »
Offline rich4822
« Reply #6 on: December 12, 2020, 01:48:31 PM »
Cheers Steve!
Offline BMCMOTO
« Reply #7 on: December 12, 2020, 05:29:03 PM »
As I recall there are 3 beveled head allen screws holding the slave cylinder to the transmission case. The bevels frequently sieze in the bevel area to the slave cylinder. Using an allen socket I always gave them a right smart smack before attempting removal. They are quite small and soft and break off or strip out the allen easily.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline rich4822
« Reply #8 on: December 14, 2020, 10:45:22 AM »
Oil level was good.
Noise has stopped so could have just been a dry bearing due to being laid up for a couple of months...
Offline rich4822
« Reply #9 on: January 13, 2021, 06:03:13 AM »
Turns out it was the starter button staying in! Who'da thunk it...  :rolleyes:
