Author Topic: Centauro front brake question  (Read 2180 times)
Offline steven c
« on: December 14, 2020, 09:41:51 AM »
 On my 97 the front discs have a lot of side to side play on the rings where my EV doesn't. It stops fine just rattles when you are pushing it around and turn the handle bars. Are they (i forgot the correct name) rings that the disc floats on a wear item or do you replace the whole rotor assembly?
« Last Edit: December 14, 2020, 12:01:33 PM by steven c »
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Tusayan
Re: Centaure front brake question
« Reply #1 on: December 14, 2020, 10:22:36 AM »
The stock disks on a Centauro are the same Japanese (Fuji) semi-floating type that were used on the EV, and do not typically rattle as you describe.  Full floating disks, for example Brembos of the same 90s era, do rattle.  Are the disks visually the same?  If so, and if they are the stock type for either bike, the normal solution would be to replace both discs, the whole assembly.  EBCs have worked fine for me on a couple of Ducatis using the same Fuji disk from new, and they are relatively imexpensive.
Online Wayne Orwig
« Reply #2 on: December 14, 2020, 11:59:00 AM »
 The retainers (pins, whatever they are called) have wave washers on them to prevent them from rattling. Maybe they have been modified.
Offline steven c
Re: Centauro front brake question
« Reply #3 on: December 14, 2020, 12:04:54 PM »
 Doubt they where modified. My late friend Ron who own the bike kept records of everything he did to it down to the date he change the batteries in the flashlight he kept under the seat and beside changing pads that's about it for brakes.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline steven c
« Reply #4 on: December 14, 2020, 12:16:33 PM »
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
jwinwi
« Reply #5 on: December 14, 2020, 01:08:19 PM »
https://youtu.be/rmceLQ3fSRk
You win! Rotors in your video are Brembo (cast iron?) Floating rotors and they are supposed to rattle. Not original to the Centauro but they were standard on Ducati 900SS-SP and probably other Ducs also. Better braking power and not as likely to warp.  :thumb:
« Last Edit: December 14, 2020, 01:10:50 PM by jwinwi »
Offline CT Dharma
« Reply #6 on: December 14, 2020, 02:05:08 PM »
FWIW my stock Centauro has the same rotors but they don't rattle like that
1980 SP1000 original owner
1998 V10 Centauro
1982 Honda CX500TC Turbo
2005 BMW R1100S BCR
1987 BMW K100RS
2022 BMW R1250RT
1998 Bimota DB3
1990 BMW K1
"When I'm riding my motorcycle, I'm glad to be alive. When I stop riding my motorcycle, I'm glad to be alive" - Neil Peart 1952-2020
Offline Tusayan
« Reply #7 on: December 14, 2020, 09:19:48 PM »
As posted above and in a Guzzi context, the rotors on the bike are Daytona RS cast iron Brembo full floating rotors, also fitted to high spec Ducatis and Laverdas of the 90s.  They rattled a lot even when new, and were also very expensive.  They have relatively soft aluminum carriers so the circumferential clearance at the pins tends to increase as they wear and this is more important than the lateral clearance they came with from new, and which makes them rattle. A guy in New Zealand made up replacement carriers made from stronger 7075 Aluminum, and given the very high performance of these rotors they make sense to some people with partially worn disks of this type, although at a pretty high price.  I bought a set and they still rattle as they did when new but the new carriers do not wear, nor do the original cast iron disks, and the bike stops like crazy.
These were the most desirable rotors for Italian bikes of the era, and when for a short period Laverda sold them as a stock replacement part at a very reasonable price, my local dealer bought out the US Laverda distributor stock immediately, mainly for sale as a Ducati upgrade and also for a few Guzzis because the Fuji disks fitted to all the brands were cheap and warp prone.  Pretty soon Laverda figured out what they were doing and raised the price.
No, they are not stock Centauro rotors... and if for some reason that and the rattle bothers you, let me know and I’ll be very happy to take them off your hands  :wink:
« Last Edit: December 14, 2020, 10:40:31 PM by Tusayan »
Offline steven c
« Reply #8 on: December 15, 2020, 07:20:59 AM »
 I have another set of rotors so they must be the stock ones. I have to say it's braking is really really good, better then my Buell's. I guess they stay on.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Online Wayne Orwig
« Reply #9 on: December 15, 2020, 08:40:11 AM »
The stock SS rotors were noted for getting contaminated spots, so called 'warped' rotors. I suspect there aren't many Centauros with original rotors.
Offline Tusayan
« Reply #10 on: December 15, 2020, 08:46:01 AM »
I’ve seen a lot warped like a potato chip, as much as 1/8 inch.
The rotors shown in the video were not stock on any Centauro.  The stock Japanese manufactured items looked like this, and had stamped carriers with round holes, stainless disks and no Brembo marking. They were sold by Brembo in order to offer a very inexpensive option to manufacturers.
In comparison, the cast iron Brembo disks in the video look like this, and had machined from solid carriers with round and triangular holes, cast iron disks and a Brembo logo on the carrier.  More info at the link, if you need it.
https://www.ducati.ms/threads/cast-iron-brembo-replica-disk-kit-ducati-6-bolt-10mm.679274/
« Last Edit: December 15, 2020, 09:10:28 AM by Tusayan »
Offline steven c
« Reply #11 on: December 15, 2020, 11:11:16 AM »
 Thanks for the info. If I put it up for sale I'll make sure I highlite the front brakes!
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Online blackcat
« Reply #12 on: December 16, 2020, 08:48:24 AM »
The first time I pushed my Daytona and heard that rattling, I was like WTF is that?
Offline steven c
« Reply #13 on: December 16, 2020, 05:50:21 PM »
 The other set of rotors (new) I have are Brembo but I found them on MG cycle web site and they are just the standard replacement ones.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
