Author Topic: Rpm speed vs gear chart.  (Read 3877 times)
Pdmartin
« on: December 15, 2020, 12:19:06 PM »
Somewhere I saw a chart for the V9 that give you your rpm by charting your speed and what gear you’re in. I thought I had copied it but can’t find it. As my V9 has no tach it would’ve been handy just for reference. Anyone have a link?
Offline SmithSwede
  • I don't want a pickle
Re: Rpm speed vs gear chart.
« Reply #1 on: December 15, 2020, 12:29:43 PM »
Do you have the owner’s manual and all the gear ratios?  Easy enough to “do the math” on this.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #2 on: December 15, 2020, 12:31:45 PM »
If you go here and scroll down there is a gearspeed program. But you need to know your ratios,
https://www.von-der-salierburg.de/download/GuzziDiag/
Offline Caffeineo
  • Guzzi B00b
« Reply #3 on: December 15, 2020, 01:20:35 PM »
https://www.gearingcommander.com/ This site has some Guzzi's but not the V9. :(
2022 Moto Guzzi V85
2023 Husky TX300
2020 KTM 500 XCW
Offline Daniel Kalal
  • Daytona, Stelvio [Kansas]
    • Trip Reports
« Reply #4 on: December 15, 2020, 01:46:29 PM »
The arithmetic is simple enough.  Do you have the ratios (gear/primary/final) out of the owner's manual (as well as your rear wheel circumference)?  I'd be happy to put something like this together for you:
Pdmartin
« Reply #5 on: December 15, 2020, 06:41:33 PM »
Thanks, everyone.
Assuming I entered the stats correctly here’s the result.
Offline chuck peterson
« Reply #6 on: December 16, 2020, 07:39:15 AM »
It’d be neat to know speed in each gear at max torque rpm so you find shift points around that area
I like to shift my v7 Nevada at 6800-7200 to get back hard into the power band when i go too fast
 :evil:
If I didn’t have a tach im sure id be lugging the motor below 3600. A steady 5500-6200 on my smallblock and that motor just sings such a sweet swiss watch tune
Don’t be afraid to get it up there! My ear may be saying it’s too much but the motor says otherwise
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline DaveJT
« Reply #7 on: December 16, 2020, 10:44:43 AM »
 :evil:
7200? I’m not a small block guy, and I know not to lug it, but man that seems high to me.  Also, should I be worried about sump capacity on the small blocks? Or is that not that much of an issue. I was gonna cafe a Cali, but maybe a v7 racer is the way to go..or baby breva..
2000 Jackal
Offline SmithSwede
« Reply #8 on: December 16, 2020, 02:13:03 PM »
I think redline is 7200 rpm.  But max horsepower is around 6200 rpm, so you don’t gain anything revving higher.
I keep my above 4,000 rpm at all times, unless I’m barely puttering through town with almost no throttle at 35 mph or below.  It is still around 3500.  Normal running is between 4000 and 5500 rpm.
I routinely run mine at 5,000 rpm or above on the interstate.
So 80 to 85 mph by GPS.  All day.
The higher capacity oil sump divides people.   Some smart people like them.   I have stayed with the stock set up for several reasons.
I don’t burn much oil, and I religiously check the level.  I’m not worried that I will suddenly lose a quart of oil without noticing it (which I think was a genuine problem with the oil rings on the older 2 throttle body small blocks).
I think the nominal 2 liters of engine oil is plenty.  People forget that most bikes share engine and gear oil, but the Guzzi has a full one liter separately devoted to the gears.
I want the oil to heat up as quickly as possible and minimize wear.  If you add more oil, you slow the warm up period.
I’m running pretty expensive synthetic oil.  I’d rather not spend another $17 for an oil change.
Finally, I’m worried about the ground clearance.   I’ve ridden over plenty of hidden curbs and other obstacles.   Just last week I hit a frost heave on a railroad track that launched the bike into the air and slammed it back down on uneven pavement.   The stock oil sump never hits anything.
Offline DaveJT
« Reply #9 on: December 16, 2020, 06:50:06 PM »
All great points. Thanks for the info !
2000 Jackal
