Author Topic: SPARK PLUG WIRES  (Read 2215 times)
Offline Spuddy
SPARK PLUG WIRES
« on: January 28, 2021, 10:20:32 AM »
Because of a crack on the stockers, and NGK iridium plugs require larger diameter caps, I need to replace plug wires on my 2000 Quota 1100ES.
What is the best place for plug wires, be it a dealer, on the internet or local auto parts store?
SPUD
'13 Stelvio NTX
'07 California Vintage
'01 W650
Re: SPARK PLUG WIRES
« Reply #1 on: January 28, 2021, 01:01:06 PM »
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
« Reply #2 on: January 28, 2021, 01:52:52 PM »
« Last Edit: January 28, 2021, 01:55:32 PM by Tom H »
Offline bmc5733946
« Reply #3 on: January 28, 2021, 02:42:48 PM »
Wires should be metalic core with NGK ends. NGK ends are available in several configurations for plugs with threaded tops or the snap lock style with the proper 5 ohm resistance. Prices for ends are usually around 5 - 10 $. The ends have a screw in the center that penetrates up the metallic core of the wire. If the wires are not original you could always convert them back to OEM using parts from the usual sources.
Brian
https://www.ngksparkplugs.co.za/products/ngk-resistor-caps/
« Last Edit: January 28, 2021, 02:50:02 PM by bmc5733946 »
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #4 on: January 28, 2021, 03:30:41 PM »
Brian
Thats a very good breakdown of the different models.It confirms what I have always thought, the resistor is for Radio/TV noise supression.
« Reply #5 on: January 28, 2021, 04:49:39 PM »
And from what I believe I have read, keeps noise out of the ECU and components.
And while we're at it. Normally, resistor caps or resistor plugs. Not both. Except....Manual for my EVT calls for both plugs and caps. Verified my stock caps as 5k ohm and it does say NGK BP"R"6ES.
Offline malik
« Reply #6 on: January 28, 2021, 05:47:03 PM »
Down here, at the other end of the world, I've found black wires & caps are available from a variety of sources, but the fancy red wire & caps were harder to find. Made by NGK Racing (not NGK, seems to be an independent arm). At least before -, it was cheaper (& easier) to get all from the Green Spark Plug Company in the UK. It was cheaper to get, say a box of plugs, from them than anywhere local.
