Author Topic: Sleeving a Master Cyl Bore Where Parts are NLA  (Read 3377 times)
Offline Cdn850T5NT
  • Cdn850T5NT
« on: February 18, 2021, 09:24:04 PM »
I recently put up a topic re the trapezoidal reservoir master cylinder (with the cylinder itself and the piston with seals both being NLA). This is from the Lario, T5, the LeMans IV, and the V35 Imola II. As shown in that post, seals ARE available (without the piston).  Well it appears that the master cylinder itself can be sleeved to brass, to hardened SS, or to type 304 SS.  Here are two references for reading-up on the process...
Note that one 'real important matter is drilling the holes in the sleeve once done. They have to be properly deburred. They also CANNOT be oversized lest the seals start to want to extrude thru the hole!  So, hardened, drawn SS tubing can be a prb due to hardness, difficulty in drilling small holes with a pin vise.
Also, the sleeve needs to be reamed to size.
See below:
Practical Machinist. https://www.practicalmachinist.com/vb/general/resleeving-motorcycle-master-cylinder-365558/
Karps Sleeving Svce. http://www.karpspb.com/sleeving.htm
Also try Whitepost Restorations
« Last Edit: February 18, 2021, 09:27:54 PM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline Roebling3
Re: Sleeving a Master Cyl Bore Where Parts are NLA
« Reply #1 on: February 19, 2021, 11:33:13 AM »
Long way from your home base, but. In the past I've witnessed these folks doing the impossible.
Quality remanufacturing. 565 E. 37th Street Paterson, NJ 07513-1179.
Marion Szostak.  USA 973-523-8800.
    Good fortune,  R3~
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #2 on: February 19, 2021, 02:01:35 PM »
Thx R3... Me, I am well provided for... but let's add that firm onto the list. Anywhere in North America is NP for any of us, I would wager.
Cheers!
Online Chuck in Indiana
« Reply #3 on: February 19, 2021, 03:56:51 PM »
Crap.. I meant to put the info on the master cylinder in my Lario Stuff file.. didn't do it, and now I can't find it. Can you point me to the other thread?
TIA
Offline moto-uno
« Reply #4 on: February 19, 2021, 05:29:09 PM »
 It may be easier to have a sleeve made from aluminum , that's what the original is made of , and a crap load easier to work with .  Peter
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #5 on: February 19, 2021, 06:12:08 PM »
TIA
Try here, at the very end:
https://wildguzzi.com/forum/index.php?topic=109205.0
Note that Gutsibits in the UK have info on the NLA Brembo kit (with piston) that suggests they may have an alternative. I suspect they modify a PS-12 piston for a round reservoir master... I will have to find that link later.
« Last Edit: February 19, 2021, 06:20:48 PM by Cdn850T5NT »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #6 on: February 19, 2021, 06:19:21 PM »
Peter, the thinness of the sleeve wall and the collapse resistance also 'hafta be considered. Aluminum may also have to be anodized for corr. resistance?
Offline moto-uno
« Reply #7 on: February 19, 2021, 11:35:33 PM »
 If you change fluid every couple of years it should be pretty easy to keep that nasty H2O out of the cylinder , no ?
I must admit I'm not all that familiar with the master cylinder you're referring to , but they usually have more than enough
material to bore out for a 2mm thick sleeve with a mild press fit . I give these as an example because of a recent experience I've had
with a rear master cylinder for a 1976 Honda Gold Wing that I made an aluminum sleeve for and it's working now . It may
very well be a case of B.S luck . I'm sure any experienced machinist in the lower mainland could do much better , there's
only 2 holes to be accurately located and sized before pressing into place . Peter
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #8 on: February 19, 2021, 11:57:17 PM »
Cool. Two year fluid changeouts... I agree. Surprised you drilled the holes beforehand. I'd have worried about the sleeve spiralling on its way in...
Cheers, John.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #9 on: February 20, 2021, 12:02:30 AM »
Oh, BTW, Peter re familiarity with that master cyl: I guess you built up a Series III T5 when you lived in central Canada... which would have had that trapezoidal master... but I guess you changed out all of the switchgear and that master to Suzuki components...? I forget the name of the fellow you did it for. He's on this board. Looked it up: Geoff in Almonte.
Or do I have my wires crossed here?
« Last Edit: February 20, 2021, 12:27:10 AM by Cdn850T5NT »
« Reply #10 on: February 20, 2021, 06:36:09 AM »
Thanks for that.. :thumb:
Offline n3303j
  • Ron Cichowski
« Reply #11 on: February 20, 2021, 08:42:07 AM »
My T3 front and rear master cylinders (Brembo) had bores specified in metric units. Turns out converting the metric specs to SAE came out exact fractions of an inch. K&S makes thin wall seamless brass tubing for the hobbyist in fractional sizes. This tubing was perfect for relining the master cylinders on my T3.
Reamed cylinder 1/32 oversize. Cut tube to length and bonded it in with Loctite RC680. Drilled and demurred cross holes and called it done. That was 75,000 miles ago. It's worked so far.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #12 on: February 20, 2021, 12:17:44 PM »
That's excellent!
Offline moto-uno
« Reply #13 on: February 20, 2021, 12:20:06 PM »
That would've been me . I had installed Yamaha switch gear and master cylinder on my Le Mans 2 even earlier and it's still there and working just fine !  Peter
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #14 on: February 20, 2021, 12:20:39 PM »
Nominally called "PS-12"... I think bore is exactly 0.500"...
« Reply #15 on: February 20, 2021, 12:26:26 PM »
The PS12 has a 12.84 mm piston, 12.84 mm = .5055"
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #16 on: February 20, 2021, 02:17:54 PM »
Oh... Not 'gonna find a reamer of that size, I imagine... ???? Is that data from a trap. reservoir master or a round reservoir master?
« Last Edit: February 20, 2021, 02:19:42 PM by Cdn850T5NT »
« Reply #17 on: February 20, 2021, 08:04:49 PM »
Oh, yeah.. .005" over is common on reamers.
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #18 on: February 21, 2021, 01:26:56 AM »
I found some contradictory info, albeit from a vendor, rather than the Mfr.  Is it possible that you viewed the rear master, at 15.84mm, and figured that the front Master was 12.84?
Please see these snaps...
And of course, there is a diametral clearance between the bore and the diameter of the piston.  I wonder what that is, and is it the same, for a range of nominal sizes of cylinder...??
« Last Edit: February 21, 2021, 01:29:43 AM by Cdn850T5NT »
Offline n3303j
  • Ron Cichowski
« Reply #19 on: February 21, 2021, 07:29:05 AM »
1/2 inch and 5/8 inch respectively.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #20 on: February 21, 2021, 10:03:11 AM »
That makes a lot of sense... 0 500 and 0.625".  The 12.67mm piston size gives ~ 0.0012" of diametral difference between bore and piston. The 15.84mm piston gives similar diametral difference.
I conclude that the round reservoir piston diameter, stated at 12.7mm, is a round-up from the correct number of 12.67mm... simply as 12.7mm piston dia. would be size-on-size... and that would not work.
So in conclusion, that's cool: these master cylinder bores are Imperial sizes 😃. Easy peasy.
« Last Edit: February 21, 2021, 10:52:47 AM by Cdn850T5NT »
Offline geoff in almonte
« Reply #21 on: February 23, 2021, 06:20:33 AM »
That would be me.  And it was Yamaha switch gear.  I last saw that bike (85 T5) at the National in NH a few years ago.  The silly thing had over 400k km on it and the owner said it was working great.
G
Midnight bugs taste best
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #22 on: February 24, 2021, 01:02:39 AM »
That's cool, Geoff!  400,000 km... (250,000 miles) - amazingly durable!
On another note, and related to the above thread:  folks might want to view this:  http://www.brakecylinder.com/index.htm
Those folks retired in 2013... but there is good instructive material in there, still, and it would appear that they do maintain their website.  They reference two of the outfits above that do sleeving.  They used to do sleeving to tempered brass, as mentioned in the graphic I attach.
« Last Edit: February 24, 2021, 01:06:35 AM by Cdn850T5NT »
Offline Furbo
« Reply #23 on: February 24, 2021, 12:42:24 PM »
A newer, better MC is not a great expense.......why not just replace the silly thing and be done with it?
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #24 on: February 24, 2021, 03:23:44 PM »
All of the switchgear, lever perches, throttle assembly, etc. are integral with the master... and for the LHS... switches and lever perch is integral.
« Last Edit: February 24, 2021, 04:50:26 PM by Cdn850T5NT »
