05 Breva 750 Fuel Leak
Topic: 05 Breva 750 Fuel Leak (Read 1030 times)
Thack
New Egg
March 05, 2021, 10:08:13 AM »
I have an odd leak from what seems like the left intake manifold port. I noticed the the injector cover had fuel all around it. I have cleaned it before the pic but there was fuel dripping from this vaccuum port.
I'm going to replace the injector cap and both o-rings. I will also inspect the hose under the heat shrink. Any other suggestions?
Muzz
On the backside of the planet.
Re: 05 Breva 750 Fuel Leak
Reply #1 on:
March 05, 2021, 12:37:35 PM »
I have no idea. Isn't that the place you put the vacuum tubes on? I'm guessing as I have never done it.
guzzisteve
"Just Ride It"
Reply #2 on:
March 05, 2021, 12:46:22 PM »
If that had a leak air would be sucked in, fuel could come out. May be running down from injector like you said. Try a hose from L to R intake ports instead of those caps or shrink coating.
