Author Topic: I hate to ask a battery question...  (Read 4816 times)
Offline AJ Huff
« on: March 19, 2021, 10:24:56 PM »
But I need to replace the battery in my California. I had an Odyssey PC545 in there. It's been over 10 years since I've bought a battery. Is Odyssey still the way to go? Has much changed in the last 10 years? Are there better options?
Thanks,
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline Scout63
Re: I hate to ask a battery question...
« Reply #1 on: March 19, 2021, 10:55:10 PM »
There are people on the forum who know much more than I do, but I’ve had great success with Shorai LI batteries. They are very light, hold a charge forever and have no acid in them.  I can’t use it with certain charging systems though, like my /5 EME system.
Ben Zehnder - Orleans, MA USA
« Reply #2 on: March 19, 2021, 11:44:13 PM »
I wouldn't go past an AGM battery, they may be heavy but on a heavy bike like yours they make little difference.
https://www.yuasabatteries.com/find-a-dealer/
I think they recommend YTX15L-BS but I would put a larger one in if you have the room.
Are you sure it's the battery though? If its failing to crank it could well be "Startus Interuptus" due to a dirty ignition switch.
Clean all the battery connections and the ground point first just to be sure, scrape the battery terminals and apply some Vaseline
https://www.thisoldtractor.com/guzzi007/schematics/2002_Stone.gif
You can test the battery and the starter by unplugging the start relay and jumping from the relay base 87 terminal (furtherest from the 2 small ones)  to touch on battery Positive.
This bypasses the ignition switch and a bunch of small wires to give the solenoid the 50 Amps it deserves. Warning, make sure the bike is in Neutral and pull the clutch for safety
Don't turn the key On, you are just testing the starter.
The ignition switches on this era Guzzi is quite easy to clean, the contact block is held on by two Phillips screws underneath, the switch block comes off leaving the lock behind,
Open up the block and wipe out the old, hard grease and refresh with Vaseline, you should really drop off the battery Negative terminal before doing that.
You might be surprised to find the bike runs better with a clean switch.
If it were me I would cut the Blue/Black wire on terminal 30 of the Start relay and wire it through a 20 Amp fuse direct from the battery (assuming you dont have an MPH kit) Sorry it's a bit trickier on this bike
I have never had an Odyssey battery but they do have a good reputation
I wouldn't go under 16AH though
I think this is the one they recommend for your California a skookum 20 AH
https://odysseybatteries.com/pc925l.htm
Check the terminal layout.
« Last Edit: March 20, 2021, 12:39:49 AM by Kiwi_Roy »
« Reply #3 on: March 20, 2021, 02:43:48 AM »
You got 10 years out of it-assuming no other issue.  Good enough for me.
« Reply #4 on: March 20, 2021, 04:32:18 AM »
True but the grease in the switch will be as hard as hell if it's never been attended to.
I wonder if MPH has ever made a fix for one of these bikes, the normal fix won't work because the headlight relay would turn on when the key is off.
Offline LaMojo
« Reply #5 on: March 20, 2021, 08:04:44 AM »
I only consider an Odyssey battery mainly because my bikes may sit for weeks/months (no battery tenders) and last up to 10 years.  That’s something I don’t have to maintain or worry about on the road.
« Reply #6 on: March 20, 2021, 08:25:25 AM »
Get the Odyssey IMHO. My old California got an Odyssey AGM battery put in it long ago. I sold it with that battery, and years later the new own still was using that battery. It was near or over 20 years old.
I used to have bad luck with Yuasa batteries. When the stock EV AGM battery went bad after only 12 years, the day before a trip, a local shop had a Yuasa AGM battery. It is called an AGM, but they had to add acid to activate it.  :violent1:  But that is still in the EV and doing fine after about 5 years. (don't use those laying down, they leak).
Offline bsanorton
« Reply #7 on: March 20, 2021, 08:45:31 AM »
My 2001 V11 sport arrived with a Odyssey battery, dead on arrival. It had a battery tender pigtail on it so not knowing I charged it overnight using my battery tender that I have had for over 15 years and rotate between bikes. Haven't had a problem since, fires right up, BUT after researching apparently I need a charger that will do AGM batteries and one that will do a deep charge for the odyssey. If I wasn't so curious about this battery (never had an odyssey, can barely spell it) I would go with my usual Yuasa or Interstate. I normally get a good 4 or 5 years in the Florida heat with a normal sealed battery. So now I'm on the lookout for a charger for the Odyssey and they are pricey, especially the Odyssey brand.
75' Norton Commando
76' GT 750 water buffalo
95' Buell S2
00' Buell X1 red strip
00' Buell X1 millennium
02' Buell M2
01' V11 Sport Rosso Mandello
05' FLHTK
Offline AJ Huff
« Reply #8 on: March 20, 2021, 10:55:32 AM »
Thanks guys. I'm pretty sure the battery is dead. It had a good life. I do have a charger for AGM batteries that I bought that was listed on Odyssey's website. It will charge for a little bit then flash Bad Bat.
Sounds like Odyssey is still the way to go. I never had a problem with the PC545 but I can look into moving up to the 925.
Thanks again,
-AJ
'71 Ambassador
'05 Road King
MGNOC# L-753
« Reply #9 on: March 20, 2021, 11:00:03 AM »
 Only 10 years ? They just don't make anything like they usta  :grin:
« Last Edit: March 20, 2021, 11:00:33 AM by oldbike54 »
« Reply #10 on: March 20, 2021, 11:04:26 AM »
My '04 has the evap system box next to the battery. Does yours? I have to remove it or just stick with the smaller battery.
Odyssey or Motobat are good. I think Motobat claims a few more cca if that matters to you.
« Reply #11 on: March 20, 2021, 11:34:08 AM »
This is the one you may want.  Handles any battery you may have for anything powered with a motor.
https://www.crutchfield.com/S-iXc8AWiW6wo/p_088US7000/CTEK-MULTI-US-7000-Battery-Charger.html
Recommended by Odyssey-use the snowflake setting for AGM battery.  It's a different output-a bit higher that a lead/acid battery which the AGM construction likes.
HERE: Cold Weather Mode: 14.7 Volts--This mode is recommended for use at temperatures at lower than 41° F (5° C). It is also recommended for many AGM batteries like Optima and Odyssey
« Last Edit: March 20, 2021, 11:39:14 AM by kingoffleece »
Offline bsanorton
« Reply #12 on: March 20, 2021, 01:44:26 PM »
i was looking at CTEK. Here is the Odyssey approved list, Docc from the V11 web site posted it for me:
 https://www.odysseybattery.com/wp-content/uploads/2020/05/ODYSSEY_approved_12V_chargers.pdf
But I still can't make up my mind which to get, so many choices
75' Norton Commando
95' Buell S2
02' Buell M2
05' FLHTK
Offline pete mcgee
« Reply #13 on: March 20, 2021, 02:50:59 PM »
Id go the oddssey again.
I had 8 years out of the last one.
Since then Ive tried 3 dekkas, 5 year through to 1.1 years(just out of warrentee). They also give issues just before they die suddenly.
Price here in Australia is the only issue I havent put another oddessey in again.
Offline ampm7
« Reply #14 on: March 20, 2021, 03:38:57 PM »
I've had my Battery Tender charger for over 20 years and use it on my AGM batteries and haven't noticed any problems.
1970 Moto Guzzi Ambassador, 1998 EV, Honda 1972 850 Ambassador, 2022 Indian Super Chief Limited
Offline bsanorton
« Reply #15 on: March 20, 2021, 04:47:31 PM »
Supposedly they can't do the 'deep' charge on the Odyssey, but what do I know. I'm still using the same battery tender (not the junior) I've had for years myself
75' Norton Commando
95' Buell S2
02' Buell M2
05' FLHTK
Offline lucky phil
« Reply #16 on: March 20, 2021, 04:58:28 PM »
Thanks,
-AJ
You want the simple answer. Yes the Odyssey is still the gold standard for a Guzzi. Go the V11lemans forum for more info. Not saying you need to follow this but there's a lot of Odyssey battery knowledge over there.
https://www.v11lemans.com/forums/index.php?/topic/18838-odyssey-pc545-battery-conditioning/
Ciao
« Last Edit: March 20, 2021, 05:02:24 PM by lucky phil »
Offline AJ Huff
« Reply #17 on: March 20, 2021, 05:40:28 PM »
Interesting..I remember when I first bought the Odyssey I thought it failed in the first month under warranty. Took it to the nearest authorized battery shop, which was an hour away, and he said I was charging it wrong. He  said I need to connect another car battery to it while charging it. Told me to take jumper cables and connect the batteries. It was soooo long ago in don't remember how, I'm assuming I did positive to positive, negative to negative. And then hook the charger to Odyssey. Sure enough it worked! And any time after that if I forgot my lights on or something and found a dead battery, that method always worked. I'd hook the bike battery to my truck battery and then the charger to the bike battery.
-AJ
'71 Ambassador
'05 Road King
MGNOC# L-753
Offline lucky phil
« Reply #18 on: March 20, 2021, 05:50:10 PM »
-AJ
You werent charging it wrong. If a battery these days drops below around 8.5 volts or so modern chargers won't charge them. The chargers now days have a safety circuit that prevents charging at low voltages and by hooking a good battery up in parallel it brings the voltage the charger sees to above the threshold and it charges both together. It a "nanny state" issue to protect us from the muppets that can't monitor a batteries state of charge during the process. Old manual chargers dont suffer from this. You can also leave the dead battery fitted and jump start and let the alternator bring the voltage up to the charge threshold as well.
Ciao
« Last Edit: March 20, 2021, 05:51:14 PM by lucky phil »
« Reply #19 on: March 20, 2021, 06:15:45 PM »
I had a nice long phone chat with a tech guy over at Odyssey last year.  He was very firm about following the info on the tech site and using the correct charger/maintainers for max battery life and reliability.  The impression I got was that a lot of field failures were due to usage  outside of the stated parameters.  As an example, I was informed that the motorcycle should show between 14.4 and 14.8 to the battery while in use.  I  know my Jackal did not put out that much.  He suggested a change in output would be very helpful for best service and reliability, field report evidence to the contrary.
Hey, it's what I was told.
« Reply #20 on: March 20, 2021, 06:32:43 PM »
The Odyssey manual states that basically a wimpy charger may damage the battery. You need a charger that can 'kick butt'.
I know that, I have heard that, and I have had dealers tell me that they had to 'revive' some Odyssey batteries with a high current charger, that had been damaged because the owner used a small trickle charger.
But, my California only charged to about 14.3 volts. And I have an Odyssey on the back porch that is lightly discharged to power a laptop, and slowly charged by a wimpy solar panel. Been using it for years with no ill effect.
Offline lucky phil
« Reply #21 on: March 21, 2021, 02:34:20 AM »
There's the statement. It's not always possible to give a battery the perfect existence so you won't get the absolute best out of it but in the majority of cases with an Odyssey they are just fine. They are sensitive to overcharging and I've killed one on a V11 Sport because the reg output was too high. It leaked its electrolite out. I replaced the battery and thought I had corrected the issue but the new battery started showing signs of it happening again so I replaced the reg. Even with the battery showing signs after cleaning it up and reinstalling it's performing fine.
Ciao
Offline Joliet Jim
  • Justus Esto, Et Non Metue
« Reply #22 on: March 21, 2021, 08:28:18 AM »
I've the 680 odyssey in the 02 Stone for about the last 8 years. 545 is in the Centauro which boiled the first 545 when the regulator ground didn't. For the Buell Blast it's something much cheaper. :)
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Offline bsanorton
« Reply #23 on: March 21, 2021, 05:14:25 PM »
Spoke to soon, Odyssey battery can't turn over the V11, 11.1 volts, i guess I need one of those expensive chargers or go back to the ways i am accustomed to.....
75' Norton Commando
95' Buell S2
02' Buell M2
05' FLHTK
Offline lucky phil
« Reply #24 on: March 21, 2021, 05:36:39 PM »
I just bought a manual battery charger off ebay for like $35AU exactly for times like this. The latest "Nanny chargers" piss me off. Just when you need them they decide you can't charge a really flat battery. All to protect morons.
Ciao
« Reply #25 on: March 21, 2021, 07:41:18 PM »
Ciao
My take on that is the tender doesn't know if its a 12 Volt or a 6 Volt battery so errs on the safe side, I have an old wall wort off a printer for that scenario It puts out 1 Amp at 14 Volts with nothing more than a transformer and rectifier.
« Reply #26 on: March 22, 2021, 08:36:14 AM »
I used to have this HUGE transformer from I don't know what old scrap mystery machine. It was not labeled at all, but was about a 15 volt AC out. I put a 50 amp bridge rectifier on the output. When a battery would act up, I would connect that thing for a couple of minutes and it would bring it to life no matter what. It would involves arcs and sparks and all kinds of good stuff.  :boozing:   If the car battery was dead, it would crank the car.
But now I just use one of that lithium jumper packs. Not as much fun, but it works.
Offline lucky phil
« Reply #27 on: March 22, 2021, 01:26:30 PM »
Yes I recently bought one of them as well. I was hoping I could use it as a straight 12V power supply with alligator leads just for the odd testing purposes around the garage as well as for jump starting but found it has a 30 second timing button for starting and 12V supply. Bugger
Ciao
« Reply #28 on: March 22, 2021, 01:41:52 PM »
I use a higher amp charger that can jolt agm batteries.  10A or car start at 50A. (15 minutes)  I've been able to revive batteries give to me by other friends.  Saves me money.   :boozing:
« Reply #29 on: March 22, 2021, 02:29:10 PM »
Over the journey I have opted for Yuasa if available, don’t know if they are the best or not but I have never had any issues whatsoever and you can’t kill them with an axe..
No need for special chargers, take a flat one to bed with you, give it a cuddle and in the morning it’ll jump start a truck..!
On my 2017 Nordkapp trip, I had a slight indication the current one (so to speak), was getting tired so I got a new one when I got off the ferry in Norway. The young bloke broke every rule (apparently) in doing the initial charge procedure, yet the thing is still working perfectly.
For me batteries are like tyres, there may be better out there, but I just “feel” better with Yuasa and Michelin.
I’ll leave the experimentation to someone else... :popcorn:
ps..
Don’t feel queasy about asking battery questions, but while you’re here can you tell me what your thoughts are on what oils you think are best...?
« Last Edit: March 22, 2021, 02:34:10 PM by Huzo »
