Thanks Bisbonian, that's what I thought too but the interface is different. The 2021 model is Euro 5 and has a square red plug, not the wide three-pin. I did get the correct lead from Lontec and the LED lights up when connected.The problem seems to be that Guzzidiag is not connecting with the Ecu.
All V85 have the same red 6 pin connector that is supposed to be on any make euro 5. But where 19-20 had an 7sm ecu that can be talked to on K line like any older injected Guzzi, the 2021 only talks on CAN bus, and Guzzidiag isn't that far. It uses a new Marelli 11MP ecu, that is used on the new 2021 Aprilia RSV4, RS660 and Tuonov4 too. We have to start all over to make it talking, and it will need a new adapter cable, not only the red one but also the KKL interface will be replaced by something else. Also the v7 850 has another ecu as we have ever used. The most radical change after 10 years Guzzidiag. If you have an automotive scanner, you can try to see if that connects and displays anything.
@ Chethro, re OBD2 readeryes I have used the one attached.MaxDia KT100 & Euro5 Adapter 6 Pin for MclIt does connect, will read codes (mine had none) and has an option to delete/reset the error codes. It was 44 Euro incl. shipping from eBay.
