Author Topic: V85TT Break In Period Question  (Read 9076 times)
Offline unionguy
« on: April 15, 2021, 05:41:39 PM »
Hello All--Picked up my 2nd ever motorcycle yesterday and my first Moto Guzzi, a V85TT and I love it so far.  Quick question that I couldn't find a clear answer online:  is the engine limited in its performance during the 900 mile break in period and then those limits go away after the first service?  thanks!
Offline TheHungarian
  • ‘13 V7
Re: V85TT Break In Period Question
« Reply #1 on: April 15, 2021, 07:42:52 PM »
I'm not sure about MG's recommended break-in process for the V85, but I'd caution you to NOT go easy on the motor during break in. I bought a low mileage V7 that's suffered from oil in the airbox (excessive blow-by) since I've had it and it's now in the shop getting a new top end. Possibly related to the dark art of the rings not seating properly during break in due to a "limp wristed" original owner.
I only know that when I retrieve the bike, I intend to thoroughly flog the new engine properly so that there's no doubt the new rings are seated. YMMV
Mike
I've owned (at one time or another):
1976 Yamaha MX125
1978 Puch moped
1985 Honda Nighthawk 700S
1993 Suzuki GSX750 Katana
1996 Honda VFR750
2013 Moto Guzzi V7 Stone
« Reply #2 on: April 15, 2021, 07:56:28 PM »
Not saying the rings are not bad but oil blow by in V7's is well know to be a result of excess oil on sump.
Offline egschade
« Reply #3 on: April 15, 2021, 08:12:52 PM »
Technically the engine is not limited. What Guzzi does is to set the shift warning light to a lower value (4750 RPM?) so that you are reminded not to over rev the engine during their recommended break in period. After the first service you just change the shift light to the true redline.
I run the engine normally, including hard acceleration, but try to stay inside that lower limit. Was the same with my new V7 III and it's shift light. I never had a problem with oil blow by but I also knew not to overfill the engine oil (middle of dipstick).
There are lots of ideas and approaches to engine break-in. Some say 'ride it like you stole it' but I prefer to do what the Guzzi engineers recommend. As we like to say in the IT world: IITFM (It's In The F'ing Manual).
« Last Edit: April 15, 2021, 08:15:03 PM by egschade »
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
  • ‘13 V7
« Reply #4 on: April 15, 2021, 08:44:30 PM »
I won't hijack this man's thread but regarding sump oil level, I've had a thread running on here since last July concerning this issue. My V7 blew oil into the airbox with as little as 1.4L of oil in the sump. All other avenues were explored. It's a top-end issue. Carry on.
Mike
1976 Yamaha MX125
1978 Puch moped
1996 Honda VFR750
Offline unionguy
« Reply #5 on: April 15, 2021, 10:26:58 PM »
Thanks all, very helpful! That's what I needed to know for now.
Offline John Croucher
« Reply #6 on: April 15, 2021, 11:35:45 PM »
I rode a demo bike at the Kentucky Rally.  It was broke in when I returned it.
Question, why do motorcycles need to be "broke in",  but new cars/trucks are never broke in?
Ride it like you stole it.  You will probably sell it before it has 10,000 miles on it.
« Reply #7 on: April 16, 2021, 03:36:50 AM »
Well, he wouldn’t be the only one guilty of that crime around here. But why throw that barb ?
Online Perazzimx14
« Reply #8 on: April 16, 2021, 04:35:55 AM »
Why do motorcycles need a 600 mile 1st service but a new cars or trucks not until 10,000 miles?
Your last sentence is spot on. Most people do not put on the mileage or keep the bike long enough to realize any minor benefits or detriments from how the motor was run during break in.
Offline egschade
« Reply #9 on: April 16, 2021, 05:55:01 AM »
With you there but I think the point is that modern car manufacturing has obviated the need for any break in period. I know a highly respected German car specialist though who would disagree. He says that all the manufacturers now provide extended maintenance windows and use 'lifetime' lubricants but the number of low-mileage engine failures he sees if markedly higher.
Most car engines are designed with lower tolerances and specific output than a MC engine and by design will require less maintenance. Consumers of cars won't accept anything less
For my new V85TT, with it's higher performance, higher spec motorcycle engine (especially an Italian one) compared to a car, I will be following the break in rules so that I don't HAVE to rebuild the engine .
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Online Perazzimx14
« Reply #10 on: April 16, 2021, 03:54:15 PM »
So you’re pushrod 1920’s tech v85 is more performance than a twin turbo Ford Transit? Don’t fool yourself. Because it’s a motorcycle doesn’t mean it’s high performance.
« Last Edit: April 16, 2021, 03:55:29 PM by Perazzimx14 »
  • ‘13 V7
« Reply #11 on: April 16, 2021, 09:07:47 PM »
 :popcorn:
1976 Yamaha MX125
1978 Puch moped
1996 Honda VFR750
Offline redhawk47
  • Traveler
« Reply #12 on: April 17, 2021, 12:12:55 AM »
Yes, keep the RPM below the shift warning light level.  My recommendation is to ride it with "vigor" and vary the speed, preferably on a winding mountain road so you are frequently changing engine speed and load.
Dan
Dan
Offline egschade
« Reply #13 on: April 17, 2021, 03:58:28 AM »
I concede the point that Guzzi uses old technology but I'm not talking about performance - newer automotive engines are incredible and yes, they don't require a break-in period. I'm referring to how the engine is designed and built. Depending on those specs the engineers come up with recommendations on how to properly prepare your engine for a long life.
Folks are free to think and do as they please with following factory guidelines. I change the oil on my turbo Audi when it gets dirty/contaminated which is well before the 'recommended' mileage.  I intend to ride it aggressively but within the break-in rev limit as noted in the manual and will release the Kraken after the initial oil change/service. I'm thinking about doing that a little early as the oil is already starting to turn dark at 450 miles.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
« Reply #14 on: April 17, 2021, 06:34:53 AM »
Dark oil tells you almost nothing about condition.
$50 says an oil analysis of either will tell you that you've got thousands of miles left if you change it just cause it got dark.
« Reply #15 on: April 17, 2021, 07:07:27 AM »
Break-in threads get close to oil threads  :grin:
Cylinder pressure is one of the key concepts.  I'll leave it there.
  • ‘13 V7
« Reply #16 on: April 17, 2021, 07:24:46 AM »
Wait. You’re going to release all 80 horsepower’s worth of “Kraken”? At the same time?? You will be good enough to give us all a 20 minute warning so that we have a chance to run for the hills first, won’t you?
Mike
1976 Yamaha MX125
1978 Puch moped
1996 Honda VFR750
Offline Moparnut72
« Reply #17 on: April 17, 2021, 07:47:00 AM »
With my Diesel Ram I wouldn't make it to the end of the driveway.    :evil:  I change when the computer tells me to.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline egschade
« Reply #18 on: April 17, 2021, 01:41:19 PM »
Mike
Did you mean to say 80 Proof? That's what I have in mind  :boozing:
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
  • ‘13 V7
« Reply #19 on: April 17, 2021, 04:40:55 PM »
Yes, I saw that. I was just Kraken a joke. Love that word.
Mike
1976 Yamaha MX125
1978 Puch moped
1996 Honda VFR750
elvisboy77
« Reply #20 on: April 18, 2021, 07:18:53 AM »
In all of these discussions about break in, oils etc I have yet to see a compelling engineering reason for NOT following the manufacturer's instruction.  Lots of opinion, no facts.  As some would say, "If all else fails, read the manual" LOL
Offline lorengo70
« Reply #21 on: April 18, 2021, 12:42:42 PM »
Here is a link of a video by mc garage where they take two new engines and flog one and follow the manuals recommendations on the other and then test and take apart the engine to see if there are any changes. Will save you the intrigue. Both look the same afterwards.
https://youtu.be/xpoglovyy_8
« Last Edit: April 18, 2021, 12:53:44 PM by lorengo70 »
2016 V7 II Stone (Black)
2015 Suzuki TU250
Offline ampm7
« Reply #22 on: April 18, 2021, 12:56:31 PM »
I think the most important factor is changing RPM's and gears frequently. In other words don't go down the freeway and leave it at one static RPM, for very long. Vary engine speed and most 2 lane roads that don't have a lot of traffic are where you can slow down, speed up, change gears frequently for generally the first 600 miles but certainly don't lug the bike. Take it up to the factory limit and decelerate then speed up and do this over and over again.
1970 Moto Guzzi Ambassador, 1998 EV, Honda 1972 850 Ambassador, 2022 Indian Super Chief Limited
