Author Topic: 2016 V7 GSA auction  (Read 3654 times)
Offline Bisbee
2016 V7 GSA auction
« on: April 15, 2021, 06:26:38 PM »
OK, boys and girls, here’s the real deal. You can STEAL this goose from the gov for next to nothing! $250 is the high bid now . 😜😜😜 Bid high , bid fast!
https://gsaauctions.gov/gsaauctions/aucitsrh/?sl=51QSCI21411010
94 R100R Mystic , 92 K75S, 98 EV, 17 Stelvio NTX
Offline egschade
Re: 2016 V7 GSA auction
« Reply #1 on: April 15, 2021, 08:19:59 PM »
Very tempting but just far enough away (8 hrs) to make it difficult. Could also be a title problem in NJ given our draconian DMV regulations. That said it could be an incredible deal and there are quite a few other bikes under $500.
Buy'em by the bunch!
« Last Edit: April 15, 2021, 08:25:11 PM by egschade »
The elder Eric in NJ
2016 V7 Stornello #394
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Online Vagrant
« Reply #2 on: April 16, 2021, 09:59:56 AM »
It would be just my luck that I'd get it at a deal and it would be one of the C/S failure units and Guzzi wouldn't cover it.
Offline sdcr
« Reply #3 on: April 16, 2021, 01:47:36 PM »
What is the “C/S failure “ that you speak of?
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #4 on: April 16, 2021, 02:29:32 PM »
There was a bad batch of crankshafts on a run of the V7II (almost or only on a run of the Stones).
On the suspect models the clutch goes out of adjustment repeatedly in the first few hundred to thousand or two miles as the crank thrust washer either fails or falls out of position allowing excessive wear and the crank starts to walk back on the block taking up the clutch free play again and again until the engine seizes.
No publicly defined VIN range for the bad cranks.
ONLY solution is complete engine replacement (at the least a short block).
This could be fine or or could very well be an undiscovered member of that club.
Offline sdcr
« Reply #5 on: April 16, 2021, 02:49:42 PM »
Kev,
Thanks, that is very good info. I assume that was just on the 2016 model year?
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #6 on: April 16, 2021, 02:52:39 PM »
Kev,
Afaik only affected V7II and that was 2016 only.
Offline Bisbee
« Reply #7 on: April 16, 2021, 03:55:12 PM »
Interesting info about crank problems. Had no idea about these potential issues. GSA states it has 186 miles. Usually , they will seize a bike, car ,etc . In a narcotics prosecution. If you’re caught, convicted then what they can grab is GONE! It ends up on these GSA auctions. Interesting to see what is for sale at times. I like when they put up a lighthouse for auction.
« Reply #8 on: April 16, 2021, 04:02:56 PM »
Surely they are not all seizures?
The website madev it sound like these were purchased and used for testing (maybe EPA related)?
Offline Bisbee
« Reply #9 on: April 16, 2021, 07:46:13 PM »
EPA related? Possible I guess but doubtful. I think most of the stuff  - from high end drug boats to planes , bikes and cars are seizures. The DEA , etc. turn them over to GSA for disposal. It’s quite a site to look thru.
« Reply #10 on: April 16, 2021, 07:56:51 PM »
But what's the chance the DEA regularly seizes vehicles with under 300 miles near Ohio.
I thought I read something in those listings about "test" vehicles.
Let me check again.
Yup, this language (U.S. Government test vehicle) was on all the Uber low mileage vehicles that I checked.
One 2016 Moto Guzzi V7. Needs a battery. Ran when it was put in storage. U.S. Government test vehicle is REPAIRABLE FOR HIGHWAY USE. ROADWORTHY, REPAIRS ARE REQUIRED. VIN#: ZGULWUB07GM200275, Est. mileage:186. 69552510360010
« Last Edit: April 16, 2021, 07:59:59 PM by Kev m »
Offline sdcr
« Reply #11 on: April 16, 2021, 08:05:52 PM »
That’s how,I interpreted the ad verbiage. Some type of governmental testing.
Let me check again.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline Bisbee
« Reply #12 on: April 16, 2021, 08:24:30 PM »
You’re right. Don’t know what they are testing for but someone will get a good deal. It’s at $1600 now and probably only needs a battery.
Offline redhawk47
  • Traveler
« Reply #13 on: April 16, 2021, 11:04:17 PM »
Now at $2105.  It looks like Bidder#2 has a higher proxy bid.
The rear brake lever looks like it has a wooden peg. Also, the right muffler looks like it is out in the breeze.
Also, the VIN is 17 off from my red V7II Stone, which had one on the bad engines.  Caveat Emptor!
Dan
Dan
Online Vagrant
« Reply #14 on: April 17, 2021, 07:47:31 AM »
"Run Forest run"!
Offline sdcr
« Reply #15 on: April 17, 2021, 08:46:11 AM »
Well, if I’m going to gamble, I’d rather it go to a good cause, like the Cadre raffle. :grin:
[quote autholink=topic=110244.msg1749392#msg1749392 date=1618622670]
[/quote]
« Last Edit: April 17, 2021, 08:46:42 AM by sdcr »
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #16 on: April 17, 2021, 01:38:47 PM »
At $2251 now.
Online LowRyter
« Reply #17 on: April 17, 2021, 07:17:32 PM »
I'd like to check out the Govt justification or proposal that got the bike purchased in the first place.   :rolleyes:
More importantly, I wonder if the operator needed that, a GSX-R or a Rokon?  Anyway, they're getting rid of it.
