Author Topic: My gas tank is so small...  (Read 12187 times)
« on: April 18, 2021, 12:38:47 PM »
Saw this Indian Scout at the local CYCLE GEAR store down in the Valley on Friday.  The owner said his gas tank is so small, he has to carry a spare Roto-PAX gas container with him all the time!!!
He said he is lucky to get 100 miles out of a tank!! :rolleyes: :rolleyes: :rolleyes: :shocked: :shocked: :shocked: :huh: :huh: :huh: Funny...the tank looks much bigger than it actually is... :rolleyes: :rolleyes: :rolleyes:
« Last Edit: April 18, 2021, 12:39:35 PM by JJ »
Offline jcctx
Re: My gas tank is so small...
« Reply #1 on: April 18, 2021, 12:46:58 PM »
Had a Honda ACE 1100 that was nearly that bad; 125 miles to reserve.
Offline ridingron
« Reply #2 on: April 18, 2021, 01:48:03 PM »
JJ-What's the range on your Centauro?
« Last Edit: April 18, 2021, 01:48:27 PM by ridingron »
Offline Moparnut72
« Reply #3 on: April 18, 2021, 02:24:28 PM »
Man, that's not much more than a Sportster with a Peanut tank. My V7lll holds quite a bit more fuel than my Audace. The Audace tank looks huge in comparison.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline bad Chad
« Reply #4 on: April 18, 2021, 03:30:45 PM »
That's not great.  The v9 has a tank rated at 3.96 gallons, but I know it will go at least 170 miles on that 4 gallon, but I haven't pushed it far enough to know.
1988 YX600 Radian
Offline flower_king001
« Reply #5 on: April 18, 2021, 03:32:16 PM »
I feel that my EV and Cali 1000i both have peanut tanks as well. Around 125 miles my fuel light comes on. Longer rides I prefer my 86 Lemans or Breva 1100
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
« Reply #6 on: April 18, 2021, 06:47:28 PM »
18 Litres / 4.7 US gal gas tank capacity -
- - 160-165 miles before the "RESERVE" light glows orange
...then MAYBE another 20-25 miles before it goes dry... :rolleyes: :shocked: :huh:  I average about 40-45 MPG... :thumb: :cool: :wink: :smiley:
« Last Edit: April 23, 2021, 08:53:22 PM by JJ »
« Reply #7 on: April 18, 2021, 07:15:39 PM »
kk
Define peanut tank?
There's the 2.3, 3.3, and then the Walnut 4.5
Anyway the Scout has a 3.3, and tends to get somewhere in the 40's mpg, so should have a theoretical 120-140 mile range.
But I know nothing about the low fuel light and what that particular rider does.
On Sportys it wasn't uncommon for an 883 to see 50+ and a good 125-140 before the small reserve with the 3.3 tank. 1200's often got a little less per gallon, closer to 40 or so.
Offline Brand X
« Reply #8 on: April 18, 2021, 07:39:19 PM »
Solid 300 with my 1100 Breva.. It holds 6.5 from dead empty.. It's been in the low 50 mpg out on the mountain roads I ride at..  I  did 320 yesterday. My 1100 monster was the best big bore MPG rig,but the pipes,weight, and tuning helped that over 60 MPG once, and a while. 4 gal tank still limits it's range compared to my Breva.. Figured the 400 pounds wet weight helped it along too.. I understand range issues, owning a new VTR Superhawk 998,Aprila twins, etc.. Although the second gen was pretty dang good..
I have my Breva setup for a 1.2 gal Rotopax, but not sure why I would need it.. Still 7.7 gals total is some long distance range..
« Reply #9 on: April 18, 2021, 09:55:55 PM »
Well guys..
The tank is the same size as when you bought it...
Offline Brand X
« Reply #10 on: April 18, 2021, 10:45:11 PM »
Well guys..
Wish that was true of all bikes, but some swell up with alkky gas.. :evil:
Offline wavedog
« Reply #11 on: April 19, 2021, 04:36:32 AM »
 Barely a hundred miles to a tank on a Scout- either that dude is on the throttle all the time or it needs to be tuned. I have two friends with three scouts between them (one owns two) and they get get 45-50 mpg.
 A few years ago there was a member of this group who rode cross country with his wife on a pair of scouts and, if I remember correctly, their gas mileage was in the high 40's.
 On the early Scouts the gas mileage was all over the map, but barely a hundred to the tank doesn't seem right. Well, they are fun to ride and twisting the throttle on a Scout is a good time, so....
Offline mechanicsavant
« Reply #12 on: April 19, 2021, 06:38:23 AM »
Tiny tank syndrome is why I dissed the V9 series , that & the fat front tire . I’ve squeezed 200 Mi. Out of my V7II on a few occasions, the charcoal canister-ectomy was one of the first modifications done .
kballowe
« Reply #13 on: April 19, 2021, 06:42:22 AM »
My 1400 tour got 120-130 before low fuel light
« Reply #14 on: April 19, 2021, 06:44:22 AM »
Squeezed?!?
What's wrong with it?
My low fuel light goes on a 200 and I usually start looking by 250. I've seen 275 and one of these days I'll SQUEEZE 300 out of it.
Oh, this weekend was funny though. I checked the tripmeter before I left home and saw I already had 150 miles on the tank, so when I hit 250 and the light hadn't come on yet I started to get worried. Got gas by 270 and only put 3 gallons in - confirming my suspect theory that I'd simply refilled it for some reason at a partial tank and forgot to reset my meter.
Offline stonelover
« Reply #15 on: April 19, 2021, 07:31:15 AM »
The large tank capacity is one of my reasons for purchasing the V7 II. Fuel light comes on at 200 miles and it fills with only four gallons. Should be able to go for 250 miles before dry. I won't push it. (Pun intended!)
Offline Ncdan
« Reply #16 on: April 19, 2021, 07:36:24 AM »
Well guys you know what that say about guys with small tanks???😂😂
kballowe
« Reply #17 on: April 19, 2021, 07:44:39 AM »
Offline DougG
« Reply #18 on: April 19, 2021, 09:07:21 AM »
Yup...like K says..."My 1400 tour got 120-130 before low fuel light".
At that point when I fill, it takes between 3.2 and 3.5 gallons.  At about 40 mpg, that's a range of 200 mi. (5.4 gal tank).  I routinely get between 40-45 mpg, depending on how and where I ride.  I may be hallucinating, but I seem to get somewhat better mpg if I fill with 93 alcohol free.  It's hard to tell without further study.
Be well, stay well,
DougG
« Reply #19 on: April 19, 2021, 09:10:53 AM »
Nice one Kevlar!
This thread title reminds me of The Carson show. How small is it?
« Last Edit: April 19, 2021, 09:12:01 AM by Guzzistajohn »
kballowe
« Reply #20 on: April 19, 2021, 09:37:07 AM »
Don't ya just hate it when ya have a small tank ???
 :boozing: :boozing: :boozing:
Offline Ncdan
« Reply #21 on: April 19, 2021, 09:42:26 AM »
Yeah I’ve heard that about you OKIES 🤔
« Reply #22 on: April 19, 2021, 09:44:53 AM »
Yes...or a wife with a "walnut bladder!!" :evil: :bow: :thumb: :boozing: :cool: :grin: :laugh: :rolleyes: :shocked:
kballowe
« Reply #23 on: April 19, 2021, 09:49:52 AM »
I'm from Missouri
SHOW ME
Offline Ncdan
« Reply #24 on: April 19, 2021, 09:58:11 AM »
I'm from Missouri
SHOW ME
Lol, yea I got you confused with the Okies😂😂😂
« Reply #25 on: April 20, 2021, 07:53:04 AM »
"My peanut gas tank is so small....but I get over 80 MPG!!" :laugh: :grin: :wink: :shocked: :rolleyes: :huh:
« Last Edit: April 20, 2021, 07:53:33 AM by JJ »
Offline TimmyTheHog
« Reply #26 on: April 20, 2021, 11:41:48 AM »
Gotta be honest that I got spoiled with V7's tank.  :boozing:
I know there are bigger one out there but almost none of them are on midsize street bikes.
Now everytime when I look for another bike, I keep on searching for anything that is around 5 gal or more... :boozing:
« Last Edit: April 20, 2021, 11:42:47 AM by TimmyTheHog »
Currently Bikeless...*cry*
Offline bigbikerrick
« Reply #27 on: April 20, 2021, 12:36:31 PM »
Brings back memories of n 98 magna 750. Tank looked huge, but it was all a big shell for the giant air box, for the 4 thirsty carbs. That bike would hit reserve at 80 miles. My wife ran it dry on reserve one time at 120 miles total!What an annoying bike on a tour.
Rick.
« Reply #28 on: April 21, 2021, 09:02:04 AM »
On my EV, the low fuel light comes on and you better find a filling station. I have run in empty at just over 100 miles, at high speed, into a South Dakota headwind.
My new V85, after a few hundred miles, the low fuel light comes on, and it has about 100 more miles left. Much better.
Offline stubbie
« Reply #29 on: April 23, 2021, 08:14:16 PM »
I've been riding with a new bunch of guys since November last year. They of course get between 400-450km out of their bikes (Honda, Yamaha, Suzuki, Kwaka). So of course I'm constantly asked " Do you need fuel" as the Griso light appears at around 220km. I fill up 3 times some days.  :weiner:
