Author Topic: Sticking stepper  (Read 8412 times)
Sticking stepper
« on: April 19, 2021, 04:30:36 PM »
Has anyone got the good info on getting some lubrication into a dry/sticking/gummed up stepper ? Just suspected at this stage, but some info born of bitter experience would be really beaut..
Thanks in advance.
Huzo.
Offline Bulldog9
Re: Sticking stepper
« Reply #1 on: April 19, 2021, 05:13:46 PM »
Huzo,
There was some talk on Griso Ghetto about this. If I recall, it was as simple as carburetor spray cleaner.
MGNOC#23231
« Reply #2 on: April 19, 2021, 05:19:23 PM »
Huzo,
Take it off and drill a small hole in the base as I recall..?
Offline Markcarovilli
« Reply #3 on: April 19, 2021, 08:01:41 PM »
Liberal dose of a product we have here called Seafoam - basically a carb cleaner...
Mark
« Reply #4 on: April 19, 2021, 10:05:23 PM »
Mark
Thanks you guys.
Offline tris
« Reply #5 on: April 20, 2021, 04:58:17 AM »
I'm sure someone somewhere recommended "trumpet oil" after cleaning
I also knocked up a little circuit using off the shelf parts so that I could "exercise" it off the bike. Let me know if that would be helpful and I'll hunt down what I did
1993 TW125 "POS" - Resting
« Reply #6 on: April 20, 2021, 08:09:09 AM »
I tried to clean carbs a few times with Seafoam. I think plain water would have worked better.
« Reply #7 on: April 20, 2021, 08:11:58 AM »
It might be over my head, but I’ll take a look if you can be bothered mate.
Thank you.
« Reply #8 on: April 20, 2021, 06:15:40 PM »
Yeah Wayne , but for cleaning in place works OK and depends on how crudy it is
Offline tris
« Reply #9 on: April 21, 2021, 12:42:12 AM »
Thank you.
You'll be fine.  Just a bit of soldering to exercise your skills to make it work
You need one of these
Ducati 848,1098,1198, idle air valve connector kit
https://www.ebay.co.uk/vod/FetchOrderDetails?itemid=302516285946&transid=1448844513020&ul_noapp=true
One of these
DC Adjustable Speed Stepper Motor Click Driver Controller with Remote Control
https://www.ebay.co.uk/itm/DC-Adjustable-Speed-Stepper-Motor-Click-Driver-Controller-with-Remote-Control/142674191361?_trkparms=aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D20200818142838%26meid%3Da351a121c72e4ea3916be3002b053c12%26pid%3D101197%26rk%3D3%26rkt%3D12%26mehot%3Dpf%26sd%3D232553250381%26itm%3D142674191361%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DItemStripV101HighAdFee%26brand%3DUnbranded&_trksid=p2047675.c101197.m1850
And a Male USB connector for the power and a 5V USB phone charger
See pics
From the board connector to the stepper connector, just match the wire colours up
For the USB power you'll need to check the polarity - I can't remember
To use you will need to fiddle with the speed, as if you get it too fast the stepper can't react, so go up and down until it does and stroke both ways
Good Luck, but shout me back if you need more
Cheers
Tris
PS Interesting fact I have used this on 2 steppers now. The one on the bike and a spare and if driven shut they BOTH leaked on one leg.
This goes some way to explaining why the bleed screws need adjusting at idle to balance this leak out and while a stepper isolation valve might be a good idea
« Last Edit: April 21, 2021, 01:43:43 AM by tris »
« Reply #10 on: April 21, 2021, 04:00:35 AM »
Thank you for treating my enquiry seriously Tris, that’s a beaut bit of kit..
Huzo.
Offline tris
« Reply #11 on: April 21, 2021, 05:47:30 AM »
My pleasure
If you're lucky you'll get the board for nothing.
It was weeks and weeks coming and eventually I lost patience and moaned at the seller who gave me the 8 quid back
3 days later it arrived - which was nice  :evil: :evil:
