My California 1100 will only run on choke.
Topic: My California 1100 will only run on choke. (Read 1794 times)
life member
New Egg
Been riding since 1958
April 19, 2021, 05:34:57 PM »
My California 1100 will only run on half to full choke. The minute you shut the choke down it immediately stalls. It has been sitting a while but the gas doesn't smell stale. It's carbs are set for Colorado 6000 feet and it is now at 2000 feet. Any help certainly would be appreciated. I'm pretty sure I ran it long enough for the engine to be warmed up. Many thanks for your help.
Kiwi_Roy
Re: My California 1100 will only run on choke.
Reply #1 on:
April 19, 2021, 05:40:59 PM »
Delorto Carb jets are probably plugged up solid, it's nit a big job to drop the float bowls and clean the jets.
I just went through it with my Eldorado that had been sitting for a year.
cloudbase
Reply #2 on:
April 19, 2021, 07:24:44 PM »
A plugged jet has been my experience as well.
Canuck750
Reply #3 on:
April 19, 2021, 07:37:58 PM »
Partial blocked idle jet will do that, if not removed and cleaned the idle jet can become blocked and its near impossible to start the bike
48 Guzzi Airone, 57 Guzzi Cardellino, 65 Benelli 200 sprite, 66 Aermacchi Sprint, 68 Gilera 106 SS, 72 Eldorado, 72 Benelli 180, 74 Guzzi 750S, 73 Laverda SF1, 74 Benelli 650S, 75 Ducati 860GT, 75 Moto Morini 3-1/2, 78 Moto Morinii 500
leroy_can
Gosling
Reply #4 on:
April 19, 2021, 09:26:21 PM »
You say it was set for 6000 but never said if it had ever ran properly or at all at the new altitude. As the others said check for obstructions in the jet but if someone put smaller ones in or turned the screws in too much it may need adjusting as well. Also the larger volume of fuel in the tank stays fresher than the small quantity in the carbs and just the act of removing the bowls to check the jets will also allow fresher fuel to refill them.
1973 XLCH cafe Shovester #1
1973 XLCH cafe Shovester #2
1971 Homemade cafe '08 XB12S motor 71 CH frame
2002 Buell M2 Cyclone
1987 LMIV SE 1400 conversion in progress
larrys
Reply #5 on:
April 20, 2021, 08:08:55 AM »
Gunky carbs. Time for a general take apart and cleaning.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
