Author Topic: The Japanese Ducati...  (Read 3300 times)
« on: April 24, 2021, 08:44:08 AM »
Always thought these were cool... :cool: :thumb: :smiley: :smiley:
Re: The Japanese Ducati...
« Reply #1 on: April 24, 2021, 09:05:50 AM »
That would look good next to your Guzzi.  :thumb:
Offline Tusayan
« Reply #2 on: April 24, 2021, 09:21:35 AM »
As I remember they had poor fuel economy (the opposite of a contemporary Ducati) and since the tank wasn’t that big, very poor fuel range.
Online Perazzimx14
« Reply #3 on: April 24, 2021, 09:25:29 AM »
Super Chickens got amazing fuel range per tank. Unfortunately not in a good way.
Its said you can pass a lot of things on these but not a gas station.
« Last Edit: April 24, 2021, 09:26:58 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
« Reply #4 on: April 24, 2021, 10:36:56 AM »
A friends brother had a red one with an aftermarket (loud) exhaust...It sounded good, as I recall on the pipe! :thumb: :wink: :cool:
Offline Murray
« Reply #5 on: April 24, 2021, 11:02:03 AM »
That middle of the road suspension and brakes, a charging system that was pretty hit and miss straight from the factory just like an older Ducati.
LesP
« Reply #6 on: April 24, 2021, 05:40:13 PM »
I think I will stick to the other one from the same period.
Easy 116 RWHP with basic add on's and suspension to suit.
Online Dukedesmo
« Reply #7 on: April 24, 2021, 05:49:58 PM »
Quote from: Tusayan on Today at 03:21:35 PM
___________________ ___________________ ___________________ ___________________ ____________
I had one, about 70 miles before fuel low light came on and not many miles after before it ran dry.
Otherwise a good bike but lacked the excitement/drama of the 916 that replaced it.
« Last Edit: April 24, 2021, 05:50:48 PM by Dukedesmo »
Le Mans II
Ducati 916
Ducati M900
Offline lucky phil
« Reply #8 on: April 24, 2021, 06:07:10 PM »
Hardly a Japanese Ducati, but a competent bike none the less as Honda's generally tend to be. Ditto on the fuel range.
The Suzuki TL's were nice engine wise but poor in the Chassis department with their silly rotary rear damper and the fame breakages at the rear spring cartridge mount.
Ciao
« Last Edit: April 24, 2021, 06:09:38 PM by lucky phil »
LesP
« Reply #9 on: April 24, 2021, 07:15:58 PM »
The TLS (not the TLR) could crack the rotary damper mounting lugs simply because the holes could be skewed a little and the rotary damper body was a slight loose fit.
The cross bolts could then loosen and rack the lug cracking it if the top bolt did not snap first.
It was easy to see based on the opposite to each other half moon contact marks on the lugs but not to much of a problem if the bolts were tight and was sporadic.
I replaced the forks (Racetech 2002 GSXR1000 and radial GSXR1000 forks and coil over Ohlins on my other TLS) back in the day and went to an Ohlins damper and machined a billet spring on a stick.
It had a larger rear sprocket by a tooth or so but would get an indicated 39 to 53 imperial mpg.
I added a Corbin seat which made it a ride all day and half the night bike.
With the TL's there were quite a few engine bits floating around (out of the USA)in the 2000's from the abandoned TL1000R race program so was buying that up along with new cylinders, low mile gearbox clusters etc.
« Last Edit: April 24, 2021, 07:27:54 PM by LesP »
Offline Scud
« Reply #10 on: April 24, 2021, 07:25:44 PM »
I also had one - in fact a yellow one, just like the picture.
Echoing previous comments, it's a fun bike for short jaunts. But I like go far, so I got frustrated by the poor range and sold it. Otherwise comfortable, reliable, good handling, sounded good (even in stock form).
If you want a Ducati, buy an Italian one. Don't buy a Honda thinking you will have a Ducati experience.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline geoff in almonte
« Reply #11 on: April 25, 2021, 07:22:26 AM »
North of the 49th they were called Firestorms.  Mine was Black.  Horrible gas mileage - looking for a fuel up at 160km, walking by 200.
RaceTech springs and an Ohlins shock took care of the suspension.  V&H cans elevated the sound.  Sargent and HeliBars made it almost comfortable.
At the time they had, I believe, the largest carbs available on a stock motorcycle (46mm).  Dynoed at 103 RWHP.
A fun and competent motorcycle - I had over 160,000km on it when I sold it.
All I really remember about the TL was that they were called 'Widowmakers' around the local watering hole.
G
Midnight bugs taste best
« Reply #12 on: April 25, 2021, 09:02:41 AM »
QUOTEIf you want a Ducati, buy an Italian one. Don't buy a Honda thinking you will have a Ducati experience.
Agree 100%...have ridden several Ducati's...never owned one...always liked them.
My buddy has a red  ST2...It is much more refined all around compared to my visceral Centauro... :wink:
Offline Brand X
« Reply #13 on: April 25, 2021, 12:39:08 PM »
Great street motor, I had the last model year brand new.. Generally will run longer then any Ducati could even think about..As long as the valve chain tensioners  are up to snuff.. Largest Carbs ever fitted to a twin motorcycle from the factory..(as said before)You could get 40 MPG on the road, but generally 30 mpg is what mine returned.. One of the nicest sounding motorcycles with stock pipes.. (IMO) Always handled like there was a hinge in the middle of the frame.. There are fixes, but a standard CBR-1000 would always be a better handling platform overall.
Online Tom
« Reply #14 on: April 25, 2021, 04:42:56 PM »
Had a friend that use his all the time.  No car.  He put on aftermarket cans on it.  Nice sound.  Never rode it and didn't know that they sucked mpg.
LesP
« Reply #15 on: April 25, 2021, 05:00:41 PM »
A pity they stopped making real Ducati's in 1985 but I guess one belt drive bike is OK.
Even these slowly got any character removed after the original 2007 1100S.
My worst on this was 110 kms to reserve. (10 litres)
« Last Edit: April 25, 2021, 05:03:22 PM by LesP »
Rough Edge racing
« Reply #16 on: April 25, 2021, 08:36:47 PM »
You must have missed the story of the Canadian 90's 900 with 250,000 miles on the original engine..It would have kept going except for a total wreck..100k miles is not unusual for a Ducati..
Offline timmythecop
« Reply #17 on: April 25, 2021, 09:35:55 PM »
I used to have an SP1. Only reason I got rid of it was it only made sense at 8 or 9 tenths. I quit while I was ahead. I ended up trading it for my SP1000.
1980 1000SP
1978 850 T3
2000 VFR800Fi
2015 Harley FLHTPi
2005 Harley XLH1200R
1995 BMW R1100GS
1992 BMW K75S
1981 Suzuki GS450T
Offline Brand X
« Reply #18 on: April 26, 2021, 12:45:38 PM »
[/quote
It's not unusual for the air cooled ducs to go far fewer miles and be totally shot also.. Superhawk is another league altogether in long distance miles..
Offline JohninVT
« Reply #19 on: April 27, 2021, 04:52:28 AM »
They stopped making real Ducati’s in 1985?  LOL...whatever.
Offline 80CX100
« Reply #20 on: April 27, 2021, 08:01:24 AM »
    I know nothing about these Hondas, but I do have to join in re the comments on the glorious sound.
    It may be a sign of immaturity or small genetalia (Prine reference lol) but a pleasing exhaust note has always meant a lot to my motorcycle experience.
     When I first started volunteering for the VRRA, I would hear this very distinctive, deep Basso Profundo working it's way around the track out of sight, and as it approached wherever I happened to be staged, I always expected a guzzi or Ducati to pop into view, but each and every time the bikes would thunder by, without fail it would be one of these Honda Hawks.  :bow:
      They may sound nice with stock pipes, but ridden in anger with open mega phones, it's like crack cocaine for a gear head's ears, js  :thumb: :evil:
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #21 on: April 27, 2021, 12:41:25 PM »
The SP1 and VTR1000F were/are completely different bikes.
G
Rough Edge racing
« Reply #22 on: April 27, 2021, 01:25:31 PM »
What you say is not what I hear...A lot of Ducatis get beat to shit on track days..Those are the ones that make the bad news stories..But if you're riding super high miles per year, a Japanese bike may be the better choice..
Offline timmythecop
« Reply #23 on: April 27, 2021, 02:14:38 PM »
Ah, I see now we are talikng about Super Hawks, not RC51s. The image in the first post is blicked on my feed, and I assumed RC51 because if its "1 liter Ducati eater" monniker.
1980 1000SP
1978 850 T3
2000 VFR800Fi
2015 Harley FLHTPi
1995 BMW R1100GS
1992 BMW K75S
1981 Suzuki GS450T
« Reply #24 on: April 28, 2021, 09:03:41 AM »
Of course, if you wanted a genuine "vintage" little DUCATI, you must open up your wallet....WIDE! :laugh: :grin:
Offline Mr Pootle
« Reply #25 on: April 28, 2021, 11:24:41 AM »
You want a Ducati? Become an Italian postman.
paul anderson youth home
