Author Topic: Resr end ticking  (Read 2885 times)
Offline shai385
Resr end ticking
« on: April 27, 2021, 03:27:34 AM »
Need some advice, I have  a center  stand  on my  v7 iii
When  I turn the wheel  ,while  the engine  is not  running
I hear  some  noise  from  the rear end,like parts  are moving  inside, as if I turn a wheel  that  has  sprockets  and chain
I looked  at another  guzzi, and its completely  silent, no noise  at all while  turning  the wheel, when  driving  I don't  hear  any  strange noises, I guss  without  the  stand  I wouldn't  have  noticed, is it normal  noises?or a beginning  of a problem?
Offline skippy
Re: Resr end ticking
« Reply #1 on: April 27, 2021, 04:39:20 AM »
You may just be hearing the the brake pads dragging on the rear disc. The pads are always just barely touching the disc ready to grab when the brake is applied. Any bike with disc brakes will have the same sound to some extent.
Skippy
23 V100 Mandello
20 V85TT
Offline shai385
« Reply #2 on: April 27, 2021, 06:24:41 AM »
Thanks, but it not  the brakes
« Reply #3 on: April 27, 2021, 06:28:36 AM »
 It could be a normal sound , how much slop is in the driveline ?
Offline Huzo
« Reply #4 on: April 27, 2021, 06:35:45 AM »
When the bike is on the stand, the uni is going through an unnaturally large angle.
Try taking off the shocks while on the centrestand and prop the swingarm up to the position it would be if it was laden.
You might find the noise disappears.
Offline Vagrant
« Reply #5 on: April 27, 2021, 06:55:56 AM »
My III has the HB CS and does the same thing. Sounds like the shaft or U joint is hitting the housing. V700 Steve installed mine and said don't worry about it, so I haven't. It's gotten 17000 on it and is still fine.
It does make me wonder what happens when people put longer than called for rear shocks and go over a severe bump and the thing really hits.
Offline shai385
« Reply #6 on: April 27, 2021, 08:16:00 AM »
When  I roll ithe bike down  a slope   I don't  hear  any  noises ,when the engine  is off
If anyone  who has a center  stand  can try  it I will really  appreciate
Offline shai385
« Reply #7 on: April 27, 2021, 08:25:40 AM »
What  is HB CS?
« Reply #8 on: April 27, 2021, 09:42:47 AM »
Listen over by the ujoint rubber, I think that's were the noise was on Vagrents. Maybe some stretch out farther than others, only happens on the centerstand. Nothing to worry about. You could listen on the end of a screwdriver also with tip on affected area.
« Reply #9 on: April 27, 2021, 09:46:41 AM »
Likely just a touch of movement in the splines. Take it apart, pack the splines with goo, see if it changes.
At may even be the bearings rattling a touch on the pinion rings. The best fix is to not listen to it when it is on the center stand.
