Author Topic: V7ii valve adjust - 1st time!  (Read 2122 times)
Offline Canyonlizzard
« on: April 29, 2021, 09:49:23 AM »
Hi,
Just gonna check/adjust my valves, first time for me, always been done at main dealer before during servicing.
My question is this; is there a recommended or commonly used torque setting for doing up the adjuster locknuts?
Or is it just a case of going by feel?
Thanks.
« Last Edit: April 29, 2021, 09:50:20 AM by Canyonlizzard »
Re: V7ii valve adjust - 1st time!
« Reply #1 on: April 29, 2021, 12:17:27 PM »
This is probably one of the best descriptions on how to tighten by feel. The adjuster nut, a few fingers tight.
Tom H
"Online Tom
    Guzzi Hero
        View Profile Personal Message (Online)
Re: I broke my spark plug, advice needed
« Reply #38 on: April 25, 2021, 01:36:27 PM »
I use torque wrenches like other have state.  Usually on fasteners that hold things together and not on spark plugs.
I do use the human torque wrench settings on the ratchet handle.  Full fist for large bolts, thumb w/index & middle finger for mid size and thumb w/index finger for small bolts.  YMMV.  No full arm strength except on the large ones and what they're tightening on.
Takes some practice and pay attention on the last 1/4 turn of the bolt etc."
Offline SmithSwede
  • I don't want a pickle
« Reply #2 on: April 29, 2021, 03:17:21 PM »
I do it by feel.   It doesn’t take much, and no, they don’t loosen so there’s no reason to gorilla tighten them.
I believe the spec for a BMW airhead was 12 foot-pounds.  Guzzi is a very similar design.
« Last Edit: April 29, 2021, 06:47:01 PM by SmithSwede »
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline sickora
« Reply #3 on: April 30, 2021, 07:36:20 AM »
As someone who just did their first valve adjust, I'll 3rd the 'go by feel'.  It's pretty easy to tell for those nuts.  Be gentle with the head cover screws, it's pretty easy to overtorque and strip them.
« Reply #4 on: April 30, 2021, 01:35:47 PM »
Thank you gentlemen, it would appear going by feel is the way forward, I’m pretty comfortable with that in the absence of a specified torque. I appreciate all your assistance.
« Reply #5 on: May 01, 2021, 08:40:34 AM »
The locknuts on a adj for valves is no more than 6ftlbs, they are tiny.  I use a torque wrench so it's all uniform. They do snap off at 7ftlbs, just so you know what you are working with.
Offline DaSwami
« Reply #6 on: May 02, 2021, 10:41:12 AM »
That's about 70 inch pounds for those with those type of torque wrenches
Offline KonaDoc
« Reply #7 on: May 02, 2021, 08:52:04 PM »
Or about 8 Nm for you metric types.
doc
2017 V7III Stone, 1972 Yamaha R5C
