Author Topic: head cover question  (Read 2582 times)
Offline Alfetta
head cover question
« on: April 29, 2021, 10:30:27 AM »
im not to keen on the looks of the cylinder head covers on my V7(3).
I prefer the looks of the V7(2) or the V85TT.
does anyone know if they will inter change.
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: head cover question
« Reply #1 on: April 29, 2021, 10:33:07 AM »
I don’t know for certain, but seeing that we’re dealing with heron heads (V7II and prior) and hemi heads (V7III, V9, V85), I’m suspecting that’s probably a no-go.
« Last Edit: April 29, 2021, 10:44:16 AM by Dirk_S »
Offline Alfetta
« Reply #2 on: April 29, 2021, 12:59:13 PM »
but ...but...my V7(3) is hemi and so is the V85tt  so.... maybe ?
« Reply #3 on: April 29, 2021, 01:01:49 PM »
Ozarks?
« Reply #4 on: April 29, 2021, 01:11:03 PM »
Was Todd (GT) selling retro (Heron head styled) valve covers for Hemi heads? Or was it just the 2TB style covers for early Heron 1Tb motors?
It was one or the other...
Yeah I would THINK V85 covers would work, but I'm not certain.
Online Dirk_S
« Reply #5 on: April 29, 2021, 01:17:40 PM »
Fitting the older 1 TB Heron valve covers onto the newer 2 TB Heron heads.
Offline Chethro
« Reply #6 on: April 29, 2021, 01:19:20 PM »
The valve cover gasket is the same for the V7III and V85. What you don't know is the distance from the base of the valve cover to the bottom of the cover bolt depressions and are they all the same bolt pattern as far as spacing. The two bolts you can see are spaced the same for the V85 and V7III, but I'm not sure about the one under the cover in relation to the outside two. The cover looks taller on the V85, but the holes for the outside two bolts are deeper.
I was wondering if the shorter valve covers on a V7III would fit on the the V85. This might allow you to remove the two screws holding spark plug wire without having to remove or raise the gas tank when doing valve adjustments.
« Last Edit: April 29, 2021, 01:41:12 PM by Chethro »
2018 DR 650
2020 V85TT
2022 V7 850 Stone
Offline Alfetta
« Reply #7 on: April 29, 2021, 01:59:18 PM »
so we both ship our right side covers to each other, question is answered and then we return or swap ??  and ill let you post up all the details and make the youtube video, so you will look like "the guy" to know...!!
Online Dirk_S
« Reply #8 on: April 29, 2021, 02:01:09 PM »
Or just call your nearest Guzzi dealer. chances are they'll know more immediately than anyone else.
Offline Chethro
« Reply #9 on: April 29, 2021, 02:02:30 PM »
Cadre wasn't sure....
In about 4000 miles, I can measure mine to see the distance between holes and bottom of hole to flange of each bolt location. For going to shorter covers, as in my case you just don't know if there is a rocker interference too... :laugh:
« Last Edit: April 29, 2021, 02:06:12 PM by Chethro »
2018 DR 650
2020 V85TT
2022 V7 850 Stone
Offline Roebling3
« Reply #10 on: April 29, 2021, 02:40:13 PM »
Might they share the same p# with a different suffix?  R3~
Offline Alfetta
« Reply #11 on: April 29, 2021, 05:03:59 PM »
i don't think any of you v85TT riders are really getting out into the nasy single track much...
I expected to see loads of scratch / cracked  rocker covers on E-bay... but no... several V7(3)'s however...
Offline Bulldog9
« Reply #12 on: April 29, 2021, 08:45:55 PM »
V7iii to V7ii is a hard no, but not sure about V7iii to v85.
MGNOC#23231
