Author Topic: Tars  (Read 1074 times)
Offline JayDee24ca
Tars
« on: May 06, 2021, 03:19:18 PM »
I have always run 110 tires on my Converts and G5, but recently ordered a set of 120s, without thinking about it first. Duh. Am I going to have a problem fitting them on my Convert?
JD
'74 Nuovo Falcone
'79 Convert
79 G5
the rest are all gone.....
Re: Tars
« Reply #1 on: May 06, 2021, 03:24:17 PM »
JD
120 on the rear will be fine, but will be tight up front, not to mention it'll "steer like a truck". I like a 100/90 on the front.
Offline Don G
Re: Tars
« Reply #2 on: May 06, 2021, 04:32:33 PM »
Maybe order up a 100 or 110 for the front and keep the other 120 for the rear, usually tyres only last about 5000 miles on the rear where I am from.  DonG
Offline JayDee24ca
Re: Tars
« Reply #3 on: May 06, 2021, 06:20:27 PM »
If it will fit as you say, I will keep them. I am running a sidecar, so it should not have the same effect on steering as it might on a solo bike. My main concern was fit. Thanks for the info!
JD
'74 Nuovo Falcone
'79 Convert
79 G5
