Rear drive splines
Topic: Rear drive splines (Read 1628 times)
czakky82
Rear drive splines
May 08, 2021, 06:54:19 PM »
So I was hoping to get a few more miles out of my tire on my T3 but I picked up a nail today which brings me to some rear wheel/drive maintenance items.
I’m wondering if I replace the splines to wheel hub on an old Tonti rear drive do I need to shim the bugger?
Or is it just a nut/bolt affair?
Bill
guzzisteve
"Just Ride It"
Re: Rear drive splines
Reply #1 on:
May 08, 2021, 07:21:06 PM »
Should be within specs. Every one I've done have checked it and was OK. Just bolts on to ring gear. Pull inner bearing off & change seals.
moto-uno
Reply #2 on:
May 08, 2021, 07:22:30 PM »
Are you speaking of the splined hub bolted to the crown gear ?
If so I believe checking the thickness of the flange that bolts to the
crown would be enough to see if there's anything more to do . Peter
czakky82
Reply #3 on:
May 09, 2021, 04:16:44 AM »
Yes Peter, that is the part. Thanks guys. Something about bevel gears makes me nervous.
I’ll order the seals and parts.
czakky82
Reply #4 on:
May 09, 2021, 04:44:42 PM »
Not exactly flush these, but I certainly could dish out the dough.
Edit: I’ll put about 4-5k on her before winter
Would you guys replace these splines?
Last Edit: May 09, 2021, 04:56:50 PM by czakky82
nc43bsa
Reply #5 on:
May 09, 2021, 06:13:39 PM »
Well greased, they should last many more miles, but if you ride long distances I would make plans to replace both within the next year or so.
My MilleGT splines were worn to sharp points.
1990 MilleGT
John A
No way to slow down...
Reply #6 on:
May 09, 2021, 06:44:25 PM »
Operating the engine consistently under 4K rpm can cause accelerated wear on driveline parts. It’s hard to tell how much wear is on the cup side but it looks better than the wheel side. Won’t know until you clean the grease off. I degrease those and put on dry film moly then grease over the top of that. Maybe you can get by with only replacing the wheel side. That’s easy and the cush should be serviced at that time since you’re there.
czakky82
Reply #7 on:
May 09, 2021, 08:04:22 PM »
Thanks guys. I think I’m going to run it for now. It seems like MG Cycle has the hubs in stock usually. Under 4K, not often.
Rear drive splines
