Author Topic: Front brake mc size  (Read 1493 times)
Online John A
Front brake mc size
« on: May 08, 2021, 07:35:26 PM »
 I’m going to put on another disc on Deb’s 02Stone because I’ve now gotten all the parts I need.  What size master cylinder do I use for a double disc non linked system?  I have that info at the shop and I’ll read over it but what experiences did you have with it?
Online RinkRat II
  • Lake Powell AZ
Re: Front brake mc size
« Reply #1 on: May 08, 2021, 11:38:21 PM »
 Here's  some good info for what your doing.  Fun With Numbers!
     http://ducatimeccanica.com/brake_ratios.html
      Good Luck
     Paul B :boozing:
Online moto
  • Fear the deer!
« Reply #2 on: May 09, 2021, 01:24:47 PM »
Another good source is Guzziology. You'll need to know the sizes of both your master and slave cylinders to get started.
850 T-3
Griso 1100 corretto
Offline John Croucher
« Reply #3 on: May 09, 2021, 02:02:48 PM »
Here are a couple of pictures on brake line routing I used to clean up appearance.
Bike originally had linked brakes.
The right size m.c. will give you two finger braking.  To small and you will have a soft lever, to big and the lever will be hard with little braking.  Just guessing, I think I used a 14mm. on the front by Brembo.
Offline moto-uno
« Reply #4 on: May 09, 2021, 03:19:22 PM »
  I might suggest you simply try it with what you have ( it may be fine , different , but fine) !   Peter
Offline Turin
« Reply #5 on: May 09, 2021, 11:45:48 PM »
I like 14mm. 15mm also alright.
1985 Sidlow Guzzi
Online skippy
« Reply #6 on: May 10, 2021, 08:21:44 AM »
I found that when I converted my 03 Stone to a twin disc setup the 17mm master cylinder I sourced from an Apillia was just about perfect. Two finger operation would provide really good feel and feed back as well as haul the bike to a full stop with little effort.
Skippy
23 V100 Mandello
20 V85TT
Online John A
« Reply #7 on: May 10, 2021, 11:33:59 AM »
When I get the bike and measure what  master came on it with the original single disc I can get an idea of how it’ll work for two discs by the charts. Thanks for the replies
« Reply #8 on: May 10, 2021, 12:12:34 PM »
It should have a PS13 front master cylinder. The calipers are P4 30/34. Using an average of 32 mm for the 4 pistons, you'd end up with a 24.2 to 1 ratio. Just for reference, the V11 Sport used a PS16 with a pair of the same calipers.
Online Tusayan
« Reply #9 on: May 10, 2021, 01:50:25 PM »
Which is equivalent to 5/8 inch, the typical master cylinder size used by almost everybody with those calipers.
« Last Edit: May 10, 2021, 01:51:49 PM by Tusayan »
