Author Topic: rear main carrier seal  (Read 1873 times)
Offline timzim
« on: May 11, 2021, 10:52:36 AM »
Hi all,
   I am on the fence about replacing my rear carrier gasket and lock washers it is not giving me a problem. If I do replace it can I keep the rear main seal ( just replaced it ) before I thought of the carrier.
Re: rear main carrier seal
« Reply #1 on: May 11, 2021, 11:03:33 AM »
Change seal unless you swapped it out recently. Need a puller for rear main pull, steering wheel puller works.
jwinwi
« Reply #2 on: May 11, 2021, 12:04:55 PM »
Yes, the existing seal can remain in the carrier. No need to replace it again.
But if it's not leaking around the gasket I wouldn't pull the carrier...
« Last Edit: May 11, 2021, 01:02:19 PM by jwinwi »
Offline Perazzimx14
« Reply #3 on: May 11, 2021, 01:11:53 PM »
If it isn't broke don't fix it until it is.
« Reply #4 on: May 11, 2021, 01:44:49 PM »
I agree
Offline timzim
« Reply #5 on: May 11, 2021, 01:58:10 PM »
Thank you for the replies I really don't want to open this can of worms I get in enough trouble with out making an appointment for it.
Offline pete mcgee
« Reply #6 on: May 11, 2021, 04:36:56 PM »
All or nothing bro.
If you are going to the effort of removing the carrier change BOTH the gasket and the seal, due to their very convenient and easy access......
Sarcasm off, as access requires near total disassembly of the bike and is a hugh PITA, do it once do it right.
While youre in there have a look at the breather gasket and the cam welsh plug as leak points.
If the rear main isnt leaking I agree with the rest of the above posts.
What are you doing thats got you in that deep?
Offline bigbikerrick
« Reply #7 on: May 11, 2021, 05:14:12 PM »
Some year ago, I replaced the rear main seal on my eldorado, as it seemed to be where the leak was. I had to take it all apart again to replace the paper gasket between the carrier and block. Thats where the leak actually was originating from. AARRGGHH!
My suggestion is do it once and do it right. If the cam plug has not been "JB Welded" over , I would do that too.
Good luck
Rick.
« Reply #8 on: May 11, 2021, 06:16:56 PM »
Sometimes, reading comprehension is a little low on WG.. :cool:
He said he'd replaced the seal.. now is worrying about the gasket.. and.. will the seal still be good?
At least that's what I'm reading.  :smiley:
I say yes.
Offline pete mcgee
« Reply #9 on: May 11, 2021, 07:00:13 PM »
I say yes.
Comprehension...... .
Yup
Agreed to both
« Reply #10 on: May 11, 2021, 07:56:26 PM »
Remember the two bolts about 7 o’clock get sealant. Degrease the cam plug and jb weld it, it’s a common leak. How old is the bike? The seal should be fine
« Last Edit: May 11, 2021, 07:57:50 PM by John A »
Offline jhem68
« Reply #11 on: May 11, 2021, 10:05:19 PM »
Tim.
  If you have replaced the seal recently and you've run without any leaks previous to taking the tranny and clutch out now, than I would say leave well enough alone. If on the other hand you are in there to address an engine oil seepage from the bell housing, then do the gasket and seal the threads on the two bolts John A referred to and JB Weld the cam plug.  Ask me how I know that this is the best approach!
Pyro has recently gone through this and can confirm.
If it wasn't leaking at all prior to your being in there and you replaced the seal to be on the safe side while you were there, I would let it go at that.
And welcome to the forum
John H
Offline timzim
« Reply #12 on: May 12, 2021, 12:50:05 PM »
Replacing the carrier gasket was just going to be preventive. I'm in here replacing my clutch on my T I will do the cam plug and breather. Thanks for the input.
