Loop generator mount/alt bracket & studs vs. bolts
Topic: Loop generator mount/alt bracket & studs vs. bolts (Read 921 times)
Mayor_of_BBQ
Instagram: @Mayor_of_BBQ
'Ever thus to deadbeats, Lebowski'
May 12, 2021, 07:45:57 AM »
I have long heard that you should replace the studs for generator mount with regular bolts. I have a simple and probably dumb question about this... Does this also apply to an alternator conversion (specifically the scrambler cycle kit)?
I'm sure bolts are probably better in either case, but I don't know if there are differences in the belt tension or other factors that come into play.
So the question: Should bikes with an alternator conversion be switched off studs to bolts, or does that only apply to bikes running stock generator & bracket?
Don G
Re: Loop generator mount/alt bracket & studs vs. bolts
Reply #1 on:
May 12, 2021, 08:57:26 AM »
You have that backasswards! Replace the bolts with shouldered studs in all cases. DonG
Last Edit: May 12, 2021, 08:58:15 AM by Don G
Antietam Classic Cycle
Happily stuck in the past.
Reply #2 on:
May 12, 2021, 09:00:06 AM »
Yes, even if using an alternator kit, hardened studs should replace the original bolts. I use large o.d., thick, flat washers and nylock nuts on the studs.
Mayor_of_BBQ
Reply #3 on:
May 12, 2021, 10:51:49 AM »
Ok I am perfect then! I have hardened studs, big washers, and nylock nuts
Thanks guys
