Author Topic: Stuck oil filter cover  (Read 2878 times)
Offline greer
« on: May 12, 2021, 08:24:47 PM »
The oil filter cover on my V7II is stuck like glue.  I searched the forum and tried everything I've read: wiggled the bolt, tapped with a mallet, pried against the fins with a screwdriver.  I drained the oil while the bike was hot but the bike was cold by the time I got back to change the filter, do you all have better luck with these things when they're hot?  I'm thinking I might run some miles with a less expensive 20w50 oil and try it again with the engine at full operating temp.  Any other ideas?? Thanks.
Sarah
Offline Kev m
Re: Stuck oil filter cover
« Reply #1 on: May 12, 2021, 08:26:08 PM »
Heat gun (carefully) or hair dryer.
Offline Vagrant
« Reply #2 on: May 13, 2021, 04:03:12 AM »
Heat gun might help but carefull use of a screwdriver works for mine. Some paint seemed to be more glue than paint and the bolt is way smaller than the hole it goes through. I wound up trying 2 different size crush washers at the same time. Hopping it will help.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #3 on: May 13, 2021, 05:15:20 AM »
Hi Sarah,
I think your idea of trying again with everything hot is a good plan.  No need to actually ride the bike.  Just let it idle for a few minutes.
I can't remember what the oil filter cover looks like.  The mallet should work, but if the geometry is such that you cannot give it a good whack, Here is what I would try.
1. plug your crankcase vent hose.
2. while the bike is hot loosen the oil filter cover retaining bolts (again I can't remember what holds the cover to the engine) enough to produce a 1/8" gap from tight.
3.  Take off the oil filler cap and use a rag to seal around a compressed air blow gun and pressurize the crankcase.  If it doesn't pop off while you or Doug are pressurizing the crankcase, the other one could tap the cover or pry on the cover.
4.  Don't loosen the bolts toooooo much or you might make a mess when the cover pops off.  Watch for your crankcase hose plug popping out.
Don't worry about exploding your crankcase, all the commercially available blow guns now are pressure limited.  I think to 35 psi.
I would avoid the lighter fluid trick used to pop tubeless tire beads into place...... for now!  I would try that on one of Doug's bikes first!!!!
Good luck.  Let us know!
« Last Edit: May 13, 2021, 05:43:38 AM by SIR REAL ED »
2019 Beta EVO 250
Offline greer
« Reply #4 on: May 13, 2021, 06:01:42 AM »
How do you go at it with the screwdriver, Vagrant?  I've tried prying against the fins and have skinned the paint here and there.  Ed, I don't know if I have the wits to go about your plan.  I thought about the heat gun but I was afraid I'd warp or damage something.  Thanks, everybody.
Sarah
Online SIR REAL ED
« Reply #5 on: May 13, 2021, 07:30:31 AM »
Sarah
Sarah,
If you get a chance, post a picture of the oil filter cover.  I would not worry about warping anything that is aluminum with a heat gun, or even a propane torch.  It would require extreme patience and lack of attention.
2019 Beta EVO 250
Offline Bulldog9
« Reply #6 on: May 13, 2021, 07:36:39 AM »
How many miles on the filter? If you think being hot will make separating easier, refill with oil, ride for 3K and then do the change again, but try the filter first.
I have a thin bladed screw driver with a bend in the tip. It slides between the cover and case and pops it right off. One time I put a small block of wood on the cover and gave it a schwack with a hammer on the front edge. Popped loose without issue.
MGNOC#23231
« Reply #7 on: May 13, 2021, 08:18:05 AM »
The pan has a bevel on it where cover fits with an oring between it. I have replaced broke ones. Block of wood on cover fins works, strait on ends not on sides.  I would not start motor.
Offline Vagrant
« Reply #8 on: May 13, 2021, 08:45:41 AM »
From the right haand side, the third fin in is the covers fin. stick a big screwdriver in as shown and pry down steadily and it will pop off if replaced before and slowly seperate if not. Heat shouldn't be needed and as I think about it might make it worse. As I recall they are cheap but don't hold me to that.
Offline Kev m
« Reply #9 on: May 13, 2021, 09:02:23 AM »
I definitely wouldn't do the air pressure thing.
The small prytool thing or block of wood sounds good!
Offline Vagrant
« Reply #10 on: May 13, 2021, 09:09:38 AM »
Yea, wouldn't blowing every seal in the bike out be a fun thing!
Also because of the lip on the cover it needs to be pried down not hit. I don't think you could get the down pressure hitting it although a few taps all over it with a small plastic hammer might not hurt. Basicly between the poor painted surfaces and the tight fit it just needs steady pressure.
« Reply #11 on: May 13, 2021, 09:18:10 AM »
Do the the bolt out before you lever on the cover.
Offline sib
« Reply #12 on: May 13, 2021, 11:53:28 AM »
That's what worked for me.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Rich A
« Reply #13 on: May 13, 2021, 03:14:06 PM »
Slightly off the wall suggestion. I was thinking that you might cut some "fingers" into a piece of PVC pipe (or something weaker than aluminum) that would fit into the grooves between the fins. Drill a hole thru the other end of the pipe and turn the pipe w a screwdriver. That might be enough to break the cover loose.
Rich A
Offline greer
« Reply #14 on: May 14, 2021, 06:34:18 AM »
Thank you, Vagrant!!  Your picture was a revelation, and your method worked like a charm.  But on my bike the filter cover had been installed so that the notched fin used for prying was on the inside, so that I had to lay on my back and look directly up under the bike to find it.  I'd already stuck my head under there and felt all around time and again, but once I was under the bike and looking straight on there it was.  Whew!! All part of buying a used bike, and no big deal now that I know.  That notched fin is the ticket!
But I'm wondering now if that might be a common install mistake, even in some service departments.  While I was searching and reading everything I could about oil filter covers I ran up on Zinfan's V85TT thread from a year and a half ago:
 https://wildguzzi.com/forum/index.php?topic=103744.0
There's discussion about using the exposed lip to tap and pry, but Zinfan replies that in feeling around the cover there's nothing to tap on. Sounds like my predicament, exactly.  Thank you again for that picture Vagrant, and thanks to the rest of you for chiming in to help.
Sarah
« Reply #15 on: May 14, 2021, 06:36:19 AM »
Offline Vagrant
« Reply #16 on: May 14, 2021, 07:33:49 AM »
Guzzi had a good idea with it but should have made it so it could only go in that way.
Online n3303j
  • Ron Cichowski
« Reply #17 on: May 14, 2021, 09:57:14 PM »
As an aside; I noted the comment stating modern air nozzles are limited to 30 PSI.
I was surprised by that comment.
Wandered over to Harbor Freight and looked at their air gun. It comes with a safety nozzle and a rubber nozzle.
https://www.harborfreight.com/blow-gun-with-safety-tip-and-rubber-tip-63577.html?
Quote advertisement "With the safety tip nozzle connected, meets OSHA safety standards of maximum inlet 90 PSI, and dead pressure less than 30 PSI." Not at all sure what "dead pressure" is. But the safety nozzle has a cross hole drilled so that if the main hole is jammed against your skin the air just exits through the cross hole.
Meanwhile the Specifications Page notes the air gun will accept 150 PSI input and will deliver 150 PSI output through the rubber nozzle.
That would make you think twice about pressurizeing a crankcase with a modern blow gun.
(On the other hand I used carb cleaner and a 150# rubber nozzle to blow through a set of plugged injectors to clear them of crud from a 7 year nap on a bike stored full of fuel.)
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online SIR REAL ED
« Reply #18 on: May 15, 2021, 09:43:21 AM »
I agree on all counts.  If you ever get the chance to test a modern blow gun side by side with an "old" one.  There will be no doubt about which one restricts outlet pressure.
About 50-55 years ago, it was great fun to play with the old style blow gun that let the full 175 psi of line pressure thru.  Dad was often not amused.  Not to hard to understand the safety restriction aspect........
« Last Edit: May 15, 2021, 07:46:18 PM by SIR REAL ED »
2019 Beta EVO 250
Offline mhershon
« Reply #19 on: May 15, 2021, 10:52:30 AM »
Sure was a pleasure to meet you in Cedar Vale, Sarah!
« Reply #20 on: May 15, 2021, 02:18:15 PM »
First time is usually the toughest.  Don’t over tighten it, or you’ll crack the cover.  Make sure the O-Ring is there and isn’t mutilated.  Use a new one if so.
Offline Moparnut72
« Reply #21 on: May 15, 2021, 09:03:22 PM »
I have never had a compressor that had a regulator that would allow more than 125lbs.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline greer
« Reply #22 on: May 15, 2021, 10:03:20 PM »
You too Maynard, along with the rest of the bunch.  Now Doug and I are pondering Keene, NH next month.  Rally fever!
Sarah
Online SIR REAL ED
« Reply #23 on: May 16, 2021, 05:23:31 AM »
kk
I'd bet several years pay on the 175 psi figure, cause as a child, I can remember seeing the gage, and watching the needle move when the compressor was turned on.  Pretty sure that was the pre OSHA days!
There wasn't much room for safety in Dad's shop.  It was viewed as limiting productivity.
Any injury was immediately followed by the chastisement of "Well?  Did you learn anything, dummy?"
2019 Beta EVO 250
Offline Moparnut72
« Reply #24 on: May 16, 2021, 09:31:24 AM »
I always turned up the pressure switch but could never find a regulator that would go over 125. In Calif any indoor compressor where there are employees must be in a cage or be ASTM certified. That used to be the law, it may stricter now.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline SmithSwede
  • I don't want a pickle
« Reply #25 on: May 16, 2021, 03:00:36 PM »
Yes.  Do NOT over tighten.   The bolt does not back out, probably due to the spring, so don’t worry about that.
I don’t tighten it much at all.  If it is a bit too loose, you might notice a drop of oil beneath that area.  Especially when the engine get cold.   If that happens, just snug it up a tiny bit more so the leak stops.  That’s all you need.
I only change the oil filter every second oil change, so around 12,000 miles.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline Vagrant
« Reply #26 on: May 16, 2021, 04:55:55 PM »
Yes, a max of two fingers and a thumb! Or a 1/4" tiny ratchet.  Otherise the crush washer goes up into the cover. Actuallly I thing just getting hot does it also.
Offline greer
« Reply #27 on: May 17, 2021, 05:27:13 AM »
Yep, I just snugged it good.  No leaks so far but I'll keep an eye on it.  Thanks again for the help!
Sarah
