Author Topic: Convert impermeable  (Read 3473 times)
Offline ...
Convert impermeable
« on: May 20, 2021, 09:03:28 PM »
Hello Convert lovers...
I have a Cali2 with Convert-Gear and now it`s leaking ATF again.
Are these numbers correct: 65x2,5mm
                                         52x2,5mm
                                          21x2,5mm for the O-rings? or maybe slightly bigger...?
Are you using original rubber or FPM?
Are you using sealant or something else?
I did this job 2 years ago and 18000 Km and all was try until now.
Kind regards
Thomas
Offline ...
Re: Convert impermeable
« Reply #2 on: May 21, 2021, 01:56:14 AM »
I know that by heart... :laugh:
Any recommendations or someone who is experienced with that issue?
Kind regards
Thomas
« Reply #3 on: May 21, 2021, 08:29:50 AM »
Male sure the flywheel & center hub are mounted DEAD NUTS. Perfect w/a dial indicator. Takes a lot of messing around but won't leak later. This is my experience.
Offline ...
« Reply #4 on: May 22, 2021, 03:18:28 PM »
Thank you...
