Author Topic: DSB08 code on 2010 Stelvio  (Read 1111 times)
Offline muddyjwj
« on: May 28, 2021, 12:35:55 PM »
I am getting a 08 code on my 2010 Stelvio.  When I looked at the diagnostics I am getting an "X" under DSB08 and the "X" is not in the active column, but in the memo column.  I did a little research and found that DSB08 is an oil pressure anomaly.  How does this differ from DSB07 which is an oil sensor failure?
I plan to clear the code and ride the bike for a while and see if the code comes back.  I can almost guarantee it will because it seems I get the warning indicator every time I travel a more than 3K RPM on the tach and at one steady RPM for more than 2 or 3 minutes.  Any suggestions on what to do next if the code comes back?
Re: DSB08 code on 2010 Stelvio
« Reply #1 on: May 28, 2021, 06:46:23 PM »
08 is no oil pressure & 07 is the sensor is broken. Almost everyone has 08 in memory.
« Reply #2 on: May 28, 2021, 07:25:41 PM »
From a momentary loss of oil pressure after an oil and filter change ...... a second or two of clattering until oil pressure builds up?
Have a great holiday weekend!
Bob
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #3 on: May 29, 2021, 09:45:14 AM »
Sometimes the gasket from the oil pan gets blown away inside the pan. There your oil pressure flows away. Errors come for a reason, just ignoring them could be an expensive thing.
Paul
Daytona 1225, Stelvio 1151
