Author Topic: Drive splines  (Read 1727 times)
Online John A
Drive splines
« on: May 29, 2021, 11:00:59 AM »
Offline berniebee
Re: Drive splines
« Reply #1 on: May 29, 2021, 11:04:34 AM »
"A recommended spline lubricant is a 50/50compound of a high temperature grease and a molybdenum disulphide powder."
Probably the most important line in the article.
Offline dxhall
Re: Drive splines
« Reply #2 on: May 29, 2021, 11:36:05 AM »
Interesting article.  My current favorite:
http://www.mgcycle.com/index.php?main_page=product_info&products_id=1914
It’s on sale.  May have to get a spare.
« Last Edit: May 29, 2021, 11:37:07 AM by dxhall »
Offline SmithSwede
  • I don't want a pickle
Re: Drive splines
« Reply #3 on: May 29, 2021, 01:08:45 PM »
I can confirm the failure mode on the small block drive splines is fretting, with the characteristic reddish brown oxide present when I go to relube them (when changing rear tires).  I’ve been using Guard Dog moly paste which is about 50% moly.  I think it is actually too dry and gets pounded out of the splines.  I plan to mix that with some of the SIG3000 to see if it stays in place better.
Here’s another interesting article.  It notes that fretting corrosion increases in a less humid environment, which is not what I would have expected.  Also seems you really want a liquid lube environment where the lube can be constantly replenished in operation.  Using grease is not optimal.
https://www.machinerylubrication.com/Read/693/fretting-wear
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Online Perazzimx14
Re: Drive splines
« Reply #4 on: May 29, 2021, 02:59:49 PM »
$8.95 shipping is a bit steep but being on sale softens the blow. $25 and change ain't bad. Order placed!
2017 Road Glide Special
2020 Kawasaki KLX300SM
Re: Drive splines
« Reply #5 on: May 29, 2021, 04:38:26 PM »
Toss in some oil filters and such to make the shipping less painful.
Online Perazzimx14
Re: Drive splines
« Reply #6 on: May 30, 2021, 04:24:34 AM »
I used to do that and ended up with more filters than the HiFlo factory :)
Offline guzziart
Re: Drive splines
« Reply #7 on: May 31, 2021, 09:35:59 AM »
On the subject of shipping, etc.....
I went online to procure front & rear brake master cylinder reservoir diaphragms for my '12 Wee Strom.  They cost about $8.95 each plus $9.95 S & H, totaling about $32 incl. tax wherever I looked and 6-10 day delivery.  So, for the heck of it, I called the local Suzuki dealer....$13.91 for both incl tax, they'll be in on wednesday or thursday.  I think I have to review my future online ordering strategy for convenience & cost effectiveness.
Oh, I did the Wurth 3000 thing + shipping with MG Cycle too... no regrets.
« Last Edit: May 31, 2021, 09:38:02 AM by guzziart »
'72 CL350, '72 Eldo '87 LMIVSE, '91 CT70, '08 Wing, '23 v85 Travel
Online Perazzimx14
Re: Drive splines
« Reply #8 on: May 31, 2021, 09:41:50 AM »
This works a lot of the time on late model motorcycles but for aftermarket or older stuff you are SOL and will incur shipping if you want the parts.
Offline Scout63
Re: Drive splines
« Reply #9 on: May 31, 2021, 10:06:02 PM »
I mix Honda moly 50/50 with high temp grease.  It was a BMW recommendation from years ago but those Germans know their lubricants.
Ben Zehnder - Orleans, MA USA
Online John A
Re: Drive splines
« Reply #10 on: June 01, 2021, 12:54:03 PM »
I clean and degrease ( like I was going to paint but not that good) then spray on dry film moly, cure with heat. Then I use wurth grease. That gives me the most longevity of splines. Another good thing is not to run below 4K with any load on it for that will hammer out splines quickly even though it will run without complaint below 4
Offline SmithSwede
Re: Drive splines
« Reply #11 on: June 01, 2021, 04:26:36 PM »
That was my original mistake.  I slathered on a lot of grease.  At the next service, I saw plenty of grease so I just put more on top.
I’m now convinced that is dead wrong.  The fretting action creates iron oxides that abrade the splines.   So you really need to remove the old grease, clean the splines thoroughly to get rid of the debris, then re-grease.
Online Perazzimx14
Re: Drive splines
« Reply #12 on: June 01, 2021, 04:35:35 PM »
Also a thin film is all thats needed. If you glob it the excess will just push off out/off during reassembly. I use flux brushes from HF to paint it on then throw away the brush. A 36 count pack is $2.49 or $1.99 with omnipresent 20% coupon so i don't feel bad about a one time use.
