Author Topic: Spring for gas tank trap door?  (Read 1719 times)
Offline berniebee
« on: June 08, 2021, 12:08:15 PM »
The spring has rusted away on this SP1000 trap door. Any hints on where to get one and HOW to replace it? Please don't tell me I have to drill out the welds on the cover and remove the entire hinge. :huh:
Re: Spring for gas tank trap door?
« Reply #1 on: June 08, 2021, 01:43:44 PM »
sure doesnt look like enough space down in that recess to push the pin out of the hinge. Yikes.
jwinwi
« Reply #2 on: June 08, 2021, 01:55:52 PM »
Isn't there a pin on which the hinge hinges? Punch it out from one end...
« Last Edit: June 08, 2021, 01:59:14 PM by jwinwi »
« Reply #3 on: June 08, 2021, 02:38:56 PM »
Try lube and tapping on the pin if not cut the pin with a Dremel.  I don't think getting it out with that much corrosion would allow the pin to come out easily.  Find pin and spring at a hardware store like ACE.
« Reply #4 on: June 08, 2021, 02:47:59 PM »
Try winding a new spring out of a bicycle spoke, they are kind of stainless as well. Just wrap it around a drill bit shank of the appropriate size.
Offline berniebee
« Reply #5 on: June 08, 2021, 06:19:36 PM »
The pin could be pushed out maybe 1/4" before it would hit the side of the trap door. In any case, my pin punch would have to come in at an angle- again because of the side of the trap door. I tried- because of the angle the pin punch gets locked up before it can push the pin 1/16" of an inch.
« Last Edit: June 08, 2021, 06:26:14 PM by berniebee »
Offline berniebee
« Reply #6 on: June 08, 2021, 06:24:49 PM »
Because of the side of the trap door, I can't get the pin punch in line with the pin. And (again) because of the side of the trap door, my dremel cutting disk would slice the side of the trap door and/or the top of the trap door before it could cut through the pin. Dang!
My guess is that the whole hinge/spring assembly was put together before the hinge was spot welded to the trap door.
« Reply #7 on: June 08, 2021, 06:26:36 PM »
Sounds like bending or cutting something.   :shocked:
« Reply #8 on: June 08, 2021, 06:29:01 PM »
What if you cut the spring and pin.  Go with 2 pins and joined in the middle of the replacement spring?
Offline nc43bsa
« Reply #9 on: June 08, 2021, 09:04:18 PM »
I can't tell from your photo, but from my memory isn't the spot-welded piece folded over the pin on both ends?
If it is, can you use a very thin flat screwdriver to work the ends of the piece open far enough to get the pin, spring, and other piece out?
Then you can replace the spring and pin, put them back in place, and fold the ends closed again.
<edit> If all that is possible, I'd replace the pin and the spring with stainless steel.
« Last Edit: June 08, 2021, 09:06:07 PM by nc43bsa »
1990 MilleGT
Online Moparnut72
« Reply #10 on: June 09, 2021, 07:17:12 AM »
Is the spring rusted through? Would it be possible to rescue the existing one with a rust rmover? Permatex make a product that does this. I can't remember the name of it but we used a lot of it in the aircraft shop.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Don G
« Reply #11 on: June 09, 2021, 01:58:04 PM »
Learn to live without the spring?  DonG
Offline rtbickel
« Reply #12 on: June 09, 2021, 02:34:06 PM »
Drill through the side of the trap door on both sides so the pin can be punched out, JB Weld the holes, sand and touch up the paint?
2020 V85TT
Offline berniebee
« Reply #13 on: June 09, 2021, 04:47:27 PM »
Thanks for all the responses. What i did was use a dremel to cut through the pin. The new cutting wheel was too large, but I wore it down to about 1/3 size on some scrap and then I was able to cut the pin with only minimal grooving on the adjacent sheet metal.
