Author Topic: Got the cali running again and.... Burnt/scorched ducati alternator rotor?????  (Read 1842 times)
Offline lazlokovacs
Maiden voyage after the big rebuild, up the first hill and my mechanic friend behind me toots his horn and I pull over. Holy smokes the alternator is smoking!!!!
Really really hot, like on fire!!!! I had visions of the whole bike going up in flames.
f--- f--- f---- I think were my choice words.
Pulled the cover off asap and very strange inside, the rotor is completely eaten away, like all the aluminium has just been scraped off, like the rotor was too tight in the stator. I certainly didn't notice any tightness when I put them together.... I might have mixed n matched a 2006 stator to 2008 rotor.... But the two rotors measured the same width in any case....
Anyone got a clue?????
Offline pat80flh
Not a clue, but glad to see you're making progress...
00 Bassa
80 FLH (in rehab)
75 850T prject
Online nc43bsa
In the past I have seen where Norton/Triumph/BSA rotors have had similar destructive events.  In their case, the rotor and stator had insufficient clearance, but since they are normally oil-cooled in the primary case, they were a little less dramatic.
In any case, it was strongly recommended that the clearance be verified with a brass feeler gauge when the stator was re-installed.  I remember checking my Mille stator when I re-installed the stator after installing the Valtek tensioner.
<edit> Oh, and it probably is obvious that you'll need a new rotor and stator.
« Last Edit: June 26, 2021, 01:04:31 PM by nc43bsa »
1990 MilleGT
WELL, at least it runs. Call Euromoto in CO and get a new one. The whole thing not 1/2.
Offline lazlokovacs
weird thing is... I don't really know what caused it...
I'm fairly certain that the ducati rotor/stator combo have no differences in diameters over the years, and it wasn't like we had to force the rotor on to the crank....
The yellow wires leading to the reg are totally undamaged...
Antone brave enough to try a theory?
woodruff key coming loose???
Stator not seated properly is the only idea I’ve got.
+1 on that. Only thing I can think of also.
Offline Rich A
Isn't there a key for the shaft? It's a little bugger, maybe it wasn't installed.
Rich A
Offline jacksonracingcomau
JUST, WOW
Outside of electric fire, I can’t get it
Watching for diagnosis, better than telly
It might’ve actually been the very first Guzzi alternator fire ever
Maybe there was a change to the rotor size, but not that I know of.
That is weird.
Offline lazlokovacs
Will have a proper look tomorrow,
in the meantime, my best hypothesis is that the old woodruff key might have been attached to the rotor???
Having said that I believe it was checked at the time of installation...
Maybe the key in the slot just worked it's way loose and got pulled into the rotor by magnetic force?
Will definitely post pics when I can, there is a deep gouge in the ally of the rotor, all the way around, the little ally shavings obviously got VERY hot, no actual flame seen, but plenty of smoke.
I promise you the cable is barely singed, although obviously the solder let go.
Hope the rotor comes off the crank without bother!
Offline Stevex
Pics?
The errant key theory makes sense, it could have moved during installation, it’s a strong magnetic attraction there.
Offline Don G
I always check them after install. .006-.008" clearance, check and rotate crank 1/4 turn, check again and repeat....    DonG
Offline lazlokovacs
update - rotor jumped the woodruff key, yikes.
I have the correct woodruff key on order and luckily a spare alternator rotor combo.
photos to follow
Offline lazlokovacs
