Author Topic: coil resistance ev  (Read 1080 times)
Offline ampm7
coil resistance ev
« on: June 26, 2021, 02:16:23 PM »
I think it is 3 ohm but, I just wanted to make sure from you guys. 1998 EV
1970 Moto Guzzi Ambassador, 1998 EV, Honda 1972 850 Ambassador, 2022 Indian Super Chief Limited
Re: coil resistance ev
« Reply #1 on: June 27, 2021, 12:04:49 AM »
The coil alone, 3 S/B right. If you measure the spark plug wire end cap through the coil to ground, I think it S/B 8. My EVT was 8 with stock plug wire caps.
« Reply #2 on: June 27, 2021, 01:19:56 AM »
Thats about right for the high Voltage circuit (8k), anyway both sides should be the same if one side is open chances are you have that nasty resistor wire.
My EV was missing on one cylinder, the resistor wire had burnt up the core, a quick fix is to poke a sewing pin in the end to bridge the gap.
Offline ampm7
« Reply #3 on: June 27, 2021, 01:38:45 PM »
Thanks guys.
