Author Topic: Lemans top end refresh - how far do I go ?  (Read 1974 times)
Offline Bazil
« on: June 26, 2021, 07:02:56 PM »
The patient - Mark IV Lemans
Age - 72,000 kms / 35 years
Vital signs - leakdown test about 8 % , compression test 125 / 127 psi , smoky exhaust , fuel consumption awful (and always has been over the last 25,000 kms)
General health -running pretty fine, despite the smoky exhaust !  :copcar:
The Lemans is in need of a top end refresh - it's getting pretty smoky, which I assume is valve guides.
I'm intending to have the valves K-lined. My question is how far do I go ?
Given the compression & leakdown results are  new rings are warranted ?
While the heads are off, is it worth considering a port job, or dual plugging the heads ? How much benefit versus expense are we looking at ? (guzzi content)
Thanks in advance from those more expert than me.
Bazil
1986 Lario ( long gone, still missed)
1985 Mark IV Lemans ( Gina)
1991 V40 Targa ( L'il Jeannie)
1962 Royal Enfield Crusader Sports
Offline moto-uno
Re: Lemans top end refresh - how far do I go ?
« Reply #1 on: June 26, 2021, 07:47:39 PM »
  If you checked compression with wide open throttle , then your compression is really low .
  Twin plugging , when all was said and done on my Le Mans 2 made it run better at lower rpm's ( never figured on that ) and allowed for a bit
more retarded timing to reduce detonation ( pinking ) .
  Porting ( if they have a flow bench or have done Guzzi heads for racing ) is usually pricey , but sure can wake up a motor with an exhaust system .
  Have someone with a proper bore gauge check your cylinders before hoping rings will be all you need .
Sure there will be more to follow :) . Peter
Offline Scout63
« Reply #2 on: June 26, 2021, 08:31:54 PM »
I can’t get into a top end without doing everything short of porting. Check cylinders, pistons, rings, valve seats, guides, head deck etc.  It just seems like short money once it is apart.
Ben Zehnder - Orleans, MA USA
« Reply #3 on: June 26, 2021, 09:33:55 PM »
I think it’s best to do rings and valves at the same time because better sealing of the valves puts more pressure on the rings and vice versa.
Offline jacksonracingcomau
« Reply #4 on: June 27, 2021, 05:52:26 AM »
Bazil
You sir,
Are one lucky chappie
Not many sellers tell you they did that (25kKm is 15 odd k miles), with  awful fuel consumption. Damage is done, but fixable..
Paint stripper is your friend, non caustic, please.
Brakeclean, alcohol ,water
Once all is clean, measure and blueprint to book
Your k liner head man will tell you about valves, guides and springs
RIngs are extremely unlikely to be usable
Followers and gudgeon pins dearer but relevant, only reuse if perfect
Yes there is much more to be had with tuning but to get normal (or better) fuel consumption is the goal to fix yours
Net sometimes misses the bleeding obvious
Symptoms maybe head gasket, guides or rings
Cause might be PO
Offline Stevex
« Reply #5 on: June 27, 2021, 11:00:08 AM »
Those compression test results are really low as already stated.
Have you considered a leak down check to find out exactly where the combustion chambers are leaking?
Offline Bazil
« Reply #6 on: June 27, 2021, 05:11:35 PM »
Stevex - the leakdown showed rings as the culprit - no noise from inlet or exhaust side, just a gentle gasp through the open oil dipstick hole.
Martin - thanks for the comments. I'll make it my mid winter project - gasket set is on order and I'll see what I need from there
cheers
Offline Groover
    • Scooteropolis
« Reply #7 on: June 29, 2021, 07:09:21 AM »
What is the normal/good compression supposed to be on those?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline moto-uno
« Reply #8 on: June 30, 2021, 07:46:45 PM »
 Not too sure if this is really relevant , but my Le Mans 2 with the stock 10.5 to 1 compression pistons ( and 2 friends with same model )
all ran over 200 psi with full throttle test . At 175 psi or lower they were noticeably softer powered .  Peter
Offline Murray
« Reply #9 on: June 30, 2021, 08:18:20 PM »
Also check the condition of the carb needles with that low compression I would of expected a 1 in front of the kms numbers but as others have said its pretty worn. You'll probably get a lot back from simply restoring compression so isolating gains from a port or twin plugging might be a little marginal. Timing chain and tensioner or a set of steel gears while its apart and you might want to look at the clutch while its easy to see.
Offline Bazil
« Reply #10 on: June 30, 2021, 08:29:46 PM »
Over 200 psi sounds impressive ! I assume that would be with pods or no air filter. Mine has the stock Mark IV airbox, which might hold things back a bit as well ?. I would have expected 160 to 180 psi if I was guessing.
Timing chain tensioner is a Valtek type and seemed to be doing it's job. Carb needles, seats and slides have about 20,000 k on them I think.
The engine guy is booked up for a month, so I'll tackle it all then, and he will check out valves, springs etc and do the k-line , while I check rings & bore
Thanks everyone
