Author Topic: Any idea what this is  (Read 3925 times)
Offline corsajim
« on: July 02, 2021, 06:12:33 AM »
Found it in the bottom of the sump yesterday, posted the image on another topic but thought I would submit it to a wider audience. Looks like a staple, but seems better engineered than a normal staple. Could it be from timing chain tensioner?
[/url]
[/img]
1100 Sport Carb
Laverda RGS Corsa
Offline yogidozer
Re: Any idea what this is
« Reply #1 on: July 02, 2021, 06:17:29 AM »
Fingernail....could n't resist  :cool:
Offline corsajim
« Reply #2 on: July 02, 2021, 06:25:17 AM »
More like thumbnail :laugh:
1100 Sport Carb
Laverda RGS Corsa
Offline Scout63
« Reply #3 on: July 02, 2021, 06:25:43 AM »
I’m stumped. Maybe a sliver off of a big end shell bearing?  That would probably involve awful noises down below.
Ben Zehnder - Orleans, MA USA
Offline corsajim
« Reply #4 on: July 02, 2021, 06:28:11 AM »
Its very soft material and non magnetic, maybe if it looks like like a staple then it probably is a staple. Just got the bike on Monday, I think I'm being over paranoid.
1100 Sport Carb
Laverda RGS Corsa
« Reply #5 on: July 02, 2021, 06:29:46 AM »
I had a small sliver of timing chain tensioner (lower hook) pass into the sump on my Eldo.  Eventually opened it up and found what was left just dangling there.
Offline yogidozer
« Reply #6 on: July 02, 2021, 06:34:52 AM »
If it's non magnetic, probably not the timing chain?
Maybe something washed down from a funnel? Doesn't look like a staple
Offline corsajim
« Reply #7 on: July 02, 2021, 06:35:52 AM »
Looking at it more closely, it does look like its been shaved off something, certainly the 'roll' on one end suggests that. I was thing tensioner perhaps
« Last Edit: July 02, 2021, 06:37:24 AM by corsajim »
1100 Sport Carb
Laverda RGS Corsa
Online John A
« Reply #8 on: July 02, 2021, 06:37:42 AM »
Not a staple, those are hard and stiff.  I’d do the next oil change a little early to check for more, it’s probably just from  manufacturing unless it’s an old engine.
Offline yogidozer
« Reply #9 on: July 02, 2021, 06:53:45 AM »
That sounds more likely.
Online aklawok
« Reply #10 on: July 02, 2021, 07:01:58 AM »
 I may be kinda noob to MG, but from what i seen recently of luigi's handy work, probably a bit of casting slag that got missed pre-assembly.
the fact that it was in tyhe sump and not the filter/strainer means it most likely came out of the gallery somewares.
« Last Edit: July 02, 2021, 07:06:43 AM by aklawok »
2007 california vintage
« Reply #11 on: July 02, 2021, 08:14:24 AM »
Since you are a "noob" and all, you may want to refrain from talkin' smack about Luigi so much, you could "offend" some "Italian Americans" You may want to pick on Guido now and then  :grin: :grin:
« Last Edit: July 02, 2021, 08:16:50 AM by Guzzistajohn »
Offline yogidozer
« Reply #12 on: July 02, 2021, 09:07:02 AM »
You think I'm funny?
Offline corsajim
« Reply #13 on: July 02, 2021, 12:38:31 PM »
Thanks guys, I'm going with the manufacturing leftovers, only done 10000 miles, so probably not had a lot of oil changes either.
1100 Sport Carb
Laverda RGS Corsa
Offline John Croucher
« Reply #14 on: July 02, 2021, 01:39:39 PM »
I found a 10 mm open box end wrench in the sump of a restoration project.  Had been in there so long that it stained the sump bottom aluminium.
Offline Iron Cross Junction
  • Location: Just above Pott's Camp along Braddock's route, Va.
« Reply #15 on: July 02, 2021, 02:05:12 PM »
Good luck with that.
Or Captain Bertorelli!  :grin:
https://www.youtube.com/watch?v=n-PEUuzMlWg
Bill
Bill Hagan
Proud Member of Moto Guzzi's Envy-of-the-Industry Post-Sale R&D Program!
1998 V11 EV [98 EV]
2004 V11 Ballabio, Sold; sigh
2007 Norge [NORJ], Sold; sigh
2010 Griso [GRISO], Sold; sigh
2016 Stornello [BEATA]
2017 V7 III [RADOŚĆ], Sold; sigh
2022 V85 Guardia
« Reply #16 on: July 02, 2021, 03:45:59 PM »
Could be the remnants of an aluminum sealing washer from a dipstick.
Offline corsajim
« Reply #17 on: July 03, 2021, 07:44:40 AM »
1100 Sport Carb
Laverda RGS Corsa
Online Perazzimx14
« Reply #18 on: July 03, 2021, 08:09:17 AM »
I'm guessing either a muffler bearing circlip H4 light bulb replacment element.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline MattP
« Reply #19 on: July 03, 2021, 04:13:19 PM »
pull the rod caps then you can rule that or not. matt
Offline corsajim
« Reply #20 on: July 03, 2021, 04:21:43 PM »
Not pulling the engine apart at this juncture, it is malleable aluminium, so not from any major component that I can think of. Buttoned up and will do an early oil change and recheck the sump.
1100 Sport Carb
Laverda RGS Corsa
