Author Topic: V85TT aftermarket exhaust  (Read 10630 times)
Offline evank
  • 2021 V85TT
« on: August 02, 2021, 05:34:02 PM »
I am a first time Moto Guzzi owner, having just purchased a new 2021 V85TT.  Having previously been a long time owner of a carbureted, analog Kawi KLR 650, my guzzi is pretty luxe.
I would like to replace the exhaust system to delete the Cat.  I like the one made by Guzzitech but am not sure it will work.  The '21 is Euro5 compliant and has sensors (Lambda?) on the
headers just as they leave the head.  Has anyone done this mod?  If so, are there any complications with the engine management system, or any other issues to be aware of?  Thanks.
« Last Edit: August 02, 2021, 05:48:42 PM by evank »
Online blu guzz
  • Loves to ride
Re: V85TT aftermarket exhaust
« Reply #1 on: August 02, 2021, 09:06:13 PM »
welcome aboard.  on my 2020 version, i put in a cat eliminator or Y pipe and left the standard pipe.  it is just a little louder, runs even better, much cooler and did not need any adjustments.  i can't speak for the 2021.
Blue Guzz
Offline Huzo
« Reply #2 on: August 03, 2021, 01:02:00 AM »
I made my own set on a mandrel bender and put the sensors behind the sump drain.
Seems to work just fine..
Online Vagrant
« Reply #3 on: August 03, 2021, 08:31:57 AM »
It sounds like the pipe diameter on the 21 is bigger. As far as I know there isn't a replacement yet. You might as well figure a mapping fix in on the deal.
Offline skippy
« Reply #4 on: August 03, 2021, 09:22:30 AM »
I certainly understand the desire to eliminate the CAT but I assure you that the need to do so on the 2021 model isn't there as it was on the 2019/2020 models. The previous model suffered from ridiculous amounts of heat eliminating off the giant collector/CAT under the transmission where as all reports from those of us who have sampled both model find that the 2021 models simply don't produce the heat. This is a good example of Moto Guzzi listening to the customer feedback and making changes. However, as you already pointed out, the new model is Euro 5 compliant and as such does have a bit of difference in the exhaust. I think your best bet is to pursue the offering from Mistral, https://www.mistralspecialparts.it/en/product/conical-exhaust-v85tt/ and see if this satisfies your needs.
Skippy
23 V100 Mandello
20 V85TT
Offline dxhall
« Reply #5 on: August 03, 2021, 09:39:17 AM »
I also would like to eliminate the catalytic converter, but I’m concerned that shlepping in a Y-pipe without remapping would cause the motor to run too lean.  Has anyone tried the Y-pipe with no other mods?
Offline evank
  • 2021 V85TT
« Reply #6 on: August 03, 2021, 09:43:49 AM »
Thanks to all.  I will check out Mistral and if that does not work, I will stay with the original stock exhaust system.  the '21 will not accept just a Y-pipe replacement as the headers are now welded the the CAT section rather than clamped.
jwinwi
« Reply #7 on: August 03, 2021, 11:14:52 AM »
Welcome to Guzziland!
Check this out... https://www.mgcycle.com/index.php?main_page=product_info&cPath=26_336&products_id=5904
Says it's in stock.
« Last Edit: August 03, 2021, 11:16:03 AM by jwinwi »
Offline egschade
« Reply #8 on: August 03, 2021, 03:13:48 PM »
What's your reason for deleting the CAT? I've read that the 2021 bikes don't run as hot as the earlier years. Maybe ride it stock for a while to see if you really need to drop a grand on an exhaust upgrade.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline evank
  • 2021 V85TT
« Reply #9 on: August 03, 2021, 06:17:54 PM »
My thinking about removing the CAT was to free up the exhaust for more performance, remove the unaesthetic CAT box, and have a cleaner simpler exhaust system.  You are correct that
the logical thing to do is keep it stock for now and see how it goes so that is what I will do.  So far it is fine and I have not noticed much heat radiating from the system even though it has been
warm here (90s).
Offline egschade
« Reply #10 on: August 03, 2021, 06:58:51 PM »
Do some research on the 2021 and find out if you actually do get any power gains. From what I recall reading it's a very minimal power improvement though it will sound better. My experience with several systems was that the only gain is at the very top end of the rev range and in some cases less power at low and mid range. What I like about the V85 is how and where it makes power, not how much.
Also, not sure how the Euro 5 tuned ECU will react to a new exhaust.
Look around this site and also check out advrider.com.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
