Author Topic: voltage regulator swap. do i need to pull the tank?  (Read 1847 times)
Offline bertelli
« on: September 01, 2021, 12:29:03 PM »
v7ii ABS
do I need to pull the tank or the connector as in visible sight, not hidden under the tank like other connectors?
thanks
Re: voltage regulator swap. do i need to pull the tank?
« Reply #1 on: September 01, 2021, 01:35:15 PM »
On my '13 V7 Stone, I just lifted the tank up and moved it rearward enough to access the connector.
Offline bertelli
« Reply #2 on: September 15, 2021, 08:04:48 PM »
Got it. So you need to remove the tank bolt in the seating area right? Anything else I should know? Thanks
« Reply #3 on: September 15, 2021, 08:22:51 PM »
It's been two years and the bike is long gone, but I do remember just removing the bolt at the back of the tank. Then I just slid it back and propped it up with some wooden blocks while I replaced the regulator.
« Reply #4 on: September 16, 2021, 05:01:33 PM »
Its probably much easier to remove the tank, you need all the help you can get to access the connectors.
Undo the bolt at the rear, pull it back then undo the pump cable and try to start it.
Starting releases all the pressure from the fuel line which makes it easier to release the quick connect.
You will also have to release the vent line, it's just pushed on.
On my V7III I also unbolted the front coil.
« Last Edit: September 16, 2021, 05:04:45 PM by Kiwi_Roy »
