Author Topic: V100 Mandello Merged Threadfest  (Read 757505 times)
Offline Bulldog9
Re: V100 Mandello Merged Threadfest
« Reply #1170 on: February 13, 2023, 08:02:16 PM »
I was chatting with Jim Hamlin from Hamlin Cycles yesterday.  One topic was service for the new bike.  They just completed factory service training.  Recommended by factory is cam removal every 15K for check/adjustment.
That answers that. I imagine that the check is cams in, but as many suspected shim adjustment is cams out. Question remains when they will/may need shim adjustments.  Not saying this is a total game changer, but does impact my decision making for potential future wallet draining activity......
MGNOC#23231
Offline HarveyMushman
    • Photo Galleries
« Reply #1171 on: February 15, 2023, 06:40:19 PM »
I don't understand the angst about cams-out shim adjustments.  Yes, it's more involved than the old screw adjuster process. But only by a small margin, and the work area is just as conveniently presented as ever.
Tim
« Reply #1172 on: February 15, 2023, 07:04:04 PM »
Many of the threads seem to be looking for a specific response, however if you just click on Reply it allows you to type anything in response, anything is better than nothing I reckon
Offline Bulldog9
« Reply #1173 on: February 15, 2023, 08:09:06 PM »
So I hear you saying when I retire and am back in VA I can drop my V100 at your place for shims? :evil:
Can't speak for anyone else, and I am a pretty decent wrench but I just hate OHC valvetrain work. I've done it on my XS11, FJR1300 and BMW M3 without catastropic (or any) failures. I'm sure there are timing marks for the cams and crank and ability to lock the tensioners back, but doing all this for two banks is too much of a PITA for me these days. Truly spoiled by the screw and nut adjusters on my Guzzi's and Porsche.
MGNOC#23231
    • Photo Galleries
« Reply #1174 on: February 16, 2023, 07:17:25 AM »
Sure, man, but shop policy is to perform extensive post-service evaluation rides.
Tim
« Reply #1175 on: February 16, 2023, 08:47:48 AM »
I looked at the shop manual and it doesn’t look that complicated, but you will need the special tool to lock the sprockets. With the adjustment period every 15,000 miles I can see having to review the manual for the first few adjustments.
Offline Madtownguzzi
« Reply #1176 on: February 16, 2023, 06:57:58 PM »
Nice review out of Germany on the 2023 Moto Guzzi V100 Mandello.
https://www.youtube.com/watch?v=YJE3-Rib59Q&t=193s
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
« Reply #1177 on: February 17, 2023, 02:07:44 AM »
I would be disconnecting those deflector things.
If I watch that video one more time, I just know I’m going to make an off colour comment.
Offline Murray
« Reply #1178 on: February 17, 2023, 08:33:06 AM »
That has a 3d printer project stamped all over it.
« Reply #1179 on: February 17, 2023, 09:26:32 AM »
"That has a 3d printer project stamped all over it."
Yes it does, especially if the cost for the special tool is an issue.
Online LowRyter
« Reply #1180 on: February 18, 2023, 05:07:56 PM »
I'm guessing there are no slots to thread in some baling wire?
Online Vagrant
« Reply #1181 on: February 18, 2023, 05:52:33 PM »
16 penny nail.
Offline ridingron
« Reply #1182 on: February 18, 2023, 07:03:20 PM »
I have a Honda with the bucket and shim set up. It is like a Guzzi but a V-4 instead of twin. At 104K miles, I pulled the valve covers to check the valves. Turn the motor over to get the valve in position. Check the clearance. Move to next valve.  All 8 were still in spec. as  from the factory. Is that because it's a Honda? Yes, if one needs adjusting, the cam must come out. It's really not that big of a deal.
It is a little bit more than the old screw adjuster process. But not much.
Offline steven c
« Reply #1183 on: February 19, 2023, 08:03:25 AM »
I just check the valves on my 2010 650 VStrom (all within spec at 18K) I wish they where that easy to get to. On the GS850 and XT350 I had, if you had to replace a shim just used a special tool ,on the GS I think I used a screw driver to compress the bucket and remove the shim pretty easy no cam to remove. But if you have to remove cam its not hard just take your time and make sure the marks line up when putting back together.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline spmoto
« Reply #1184 on: February 19, 2023, 11:35:30 AM »
Has anyone here actually ridden off the dealer's lot with one of these yet???
Offline mechanicsavant
« Reply #1185 on: February 19, 2023, 12:27:15 PM »
It has been my experience w/shim over or under bucket that once everything is settled in , valve clearances hardly vary at all . This is based on a number of Asian & European OHC engines . That’s not to say there won’t be a few “anomalies “ out there , but there is a boatload of experience out there . I am kinda wondering why they didn’t use a finger follower type arrangement either with hydraulic, or mechanical adjusters . Cost , maybe? Simplicity?
« Reply #1186 on: February 19, 2023, 12:31:42 PM »
Could be wrong, but I reckon if anybody had one, it might have come up in conversation.
Offline dguzzi
« Reply #1188 on: February 19, 2023, 02:31:22 PM »
  They have a poor track record  (See Hydro problems)  Also the Griso issues leading to rollers.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
« Reply #1189 on: February 19, 2023, 03:34:02 PM »
I don’t understand what you mean.
« Reply #1190 on: February 19, 2023, 05:55:34 PM »
It means they could be junk, and what electrics won't work, dash etc.
Online LowRyter
« Reply #1191 on: February 19, 2023, 09:57:49 PM »
yes you do   :evil:
« Reply #1192 on: February 19, 2023, 11:40:12 PM »
yes you do   :evil:
I take your point LR, but it was a bit obscure.
Offline steven c
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #1194 on: February 20, 2023, 06:28:54 AM »
From what I’ve read there is a problem with a coolant line on some bikes. A few owners have shown pictures of minor leakage from the same hose clamp. And a couple have reported rattling windshield armatures which were easily tightened.
Offline bad Chad
« Reply #1195 on: February 20, 2023, 09:02:50 AM »
Lots of people have ridden off the lot, just not yet in North America.
Or perhaps some have, but they don’t like the incessant complaining so prevalent here?
1988 YX600 Radian
« Reply #1196 on: February 20, 2023, 09:15:14 AM »
Well, that was certainly a well written and thought out piece on the new bike.
One of the very best reviews I've ever read about any motorcycle.  Thoughtful intelligent discussion with an historical backdrop.  Very entertaining to say the least.
Offline skippy
« Reply #1197 on: February 20, 2023, 10:35:08 AM »
I will second that. This is a really well written and concise review of not only the V100 but of Moto Guzzi as a whole.
Skippy
23 V100 Mandello
20 V85TT
« Reply #1198 on: February 20, 2023, 11:30:20 AM »
Don’t be too hard on yourself Chad, you’re not that bad.
Offline jrt
« Reply #1199 on: February 20, 2023, 11:50:41 AM »
Skippy
Thirded.  I found his description of the cruise control rather amusing.  A little weird that the CC doesn't shut off with light clutch actuation.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
