Author Topic: Cast wheels for a T3?  (Read 1632 times)
Offline smsw
« on: September 17, 2021, 08:22:10 PM »
Does anyone know if later model (than my '77 T3) cast (tubeless) wheels are a drop in replacement for the OEM spoked aluminum wheels?
What year and what bike were they on?
Offline Scout63
Re: Cast wheels for a T3?
« Reply #1 on: September 17, 2021, 09:27:42 PM »
I don’t know the answer, but if you have a good set of Borrani spoked rims and hubs hang on to them. You’ll be glad you did. They clean up very nicely.
Ben Zehnder - Orleans, MA USA
Offline guzzista
« Reply #2 on: September 18, 2021, 12:34:09 AM »
Cast wheels of a Sp1000 or a later T3/G5 Convert and Cali 2 cast wheels should bolt up as served as fork spacing is the same (195mm).  The LMs 1,2,3  fronts are narrower at the hub IIRC.
Offline mtiberio
    • TiberioRacing
« Reply #3 on: September 18, 2021, 05:45:51 PM »
True this, but you will have to do a tubeless conversion (simple).
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline smsw
« Reply #4 on: September 18, 2021, 07:02:45 PM »
I'm not sure what you mean.  I know I can coat the inside of my existing wheels with silicone caulk or 3M 5200, but my original question may have been poorly phrased.  Are there any ready to go tubeless MG wheels that are a straight replacement for my T3's wire spoked wheels?
Offline mtiberio
    • TiberioRacing
« Reply #5 on: September 19, 2021, 09:08:47 AM »
 No, plus the casts are super heavy. Ride and acceleration suffer
Offline Groover
    • Scooteropolis
« Reply #6 on: September 19, 2021, 09:11:53 AM »
You could try and find a older set of Lester wheels. Not particularly easy to find, but they pop-up from time to time.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline guzzista
« Reply #7 on: September 19, 2021, 10:40:25 AM »
All the  dog leg spoked wheels (LM 850 style) can easily be  tubeless with a valve installed  in place of the tube. They don't have the so called  safety  hump , but lots of folks myself included have run them tubeless for a long time  . True what Mike says about weight. The straight spoke wheels are  a bit lighter ( not sure by how much) and they were served on  Cali 2  and  some LM3 in Europe/ ROW. The ones for the LM have a narrower hub at the front
