Author Topic: 1400 maps  (Read 1963 times)
Offline guzziken15
1400 maps
« on: September 18, 2021, 09:52:24 PM »
Does anyone know if beetle is still around and has a cure for the 3k RBW throttle problem on the 1400?
Offline tris
Re: 1400 maps
« Reply #1 on: September 19, 2021, 12:26:31 AM »
 You'll find him and the maps here     https://www.griso.org/
1993 TW125 "POS" - Resting
Offline Moparnut72
Re: 1400 maps
« Reply #2 on: September 19, 2021, 09:07:51 PM »
The last I knew he wasn't doing any right now due to a few ECUs getting bricked. If anyone knows anything different, chime in. I would like to do mine also.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline dragger
Re: 1400 maps
« Reply #3 on: September 20, 2021, 06:25:21 AM »
He started doing them again. Just had one made for mine about a month ago.
Offline Moparnut72
Re: 1400 maps
« Reply #4 on: September 20, 2021, 10:35:12 AM »
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Guzziman22
Re: 1400 maps
« Reply #5 on: September 21, 2021, 09:53:24 AM »
I have the same problem with my '14 1400, except it hangs up at various speeds, including very slow idle-down.  Afraid to ride it.  Dealer says they've never heard of the problem.
Offline Moparnut72
Re: 1400 maps
« Reply #6 on: September 21, 2021, 09:53:37 PM »
What dealer is that? He can ride mine.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online Ncdan
Re: 1400 maps
« Reply #7 on: September 21, 2021, 10:28:39 PM »
I’ll check with Lucian here on the forum and see if he has encountered this issue. He has a 2014 1400 with around 30k miles and as far as I know he has not had any issues with that bike.
Offline mondtster
Re: 1400 maps
« Reply #8 on: September 22, 2021, 03:50:21 PM »
I can't speak to the availability of a 1400 map but I know that Mark has started helping folks with the 2020 MY V85TT again, which shares the same ECU. As mentioned above, there was a thread here a year or so ago stating that support was going to be temporarily discontinued due to the risk of bricking the ECU. I'd contact him and see what he says.
I can tell you this, if you do flash the ECU follow Mark's instructions closely. The 7SM ECU is the most finicky ECU I've flashed, and I've flashed a lot of them.
Offline moto-uno
Re: 1400 maps
« Reply #9 on: September 22, 2021, 09:15:55 PM »
 I had the privilege of installing one of his maps on my stock 2018 Eldorado and I wouldn't change it for anything  else . It's a  bit of a process  , but it was a simple case of going over everything a few times and following  his directions posted here earlier . Peter
Offline Guzziman22
Re: 1400 maps
« Reply #10 on: September 24, 2021, 02:33:39 PM »
kk
GP Motpsports in  San Diego.  They gave me all kind of runaround.  Want to do a $500 service.  Can't give me a straight answer about re-flashing the ECM.  Think I'm just gonna dump the bike.
Online lucian
Re: 1400 maps
« Reply #11 on: September 24, 2021, 04:56:28 PM »
Haven't had this issue myself but some others have and it seems to happen mostly when very hot. Sounds like a lean condition and could have more than one cause . I would definitely check for any stored faults and also confirm that all the basic stuff is in order like valve adjustment , handle and throttle learners reset ect. Check for intake and exhaust leaks also.  This thread on GT dives into it a bit and on page twelve the poster claims his was due to a bad crank sensor which I think would throw a dash code.
     https://www.guzzitech.com/forums/threads/california-1400-hanging-throttle.14996/page-12
