Author Topic: Lemans 4, rear wheel removal.  (Read 1674 times)
Offline mtiberio
    • TiberioRacing
« on: September 22, 2021, 03:31:20 PM »
Tell me I don't have to unbolt the caliper from the caliper hanger?
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Online Chuck in Indiana
Re: Lemans 4, rear wheel removal.
« Reply #1 on: September 22, 2021, 03:40:50 PM »
At least you don't have an early Spot.  :grin: :boozing:
Online Groover
    • Scooteropolis
« Reply #2 on: September 22, 2021, 03:44:30 PM »
I was surprised to find out that you have to remove the battery and battery tray to replace the front rubber battery strap.. (try and say that 3 times really fast)
« Last Edit: September 22, 2021, 03:45:12 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline ccoli
  • What? Me Worry?
« Reply #3 on: September 22, 2021, 03:54:52 PM »
IIRC only one bolt and loosen the other one.
Wisconsin MGNOC Rep
Offline mtiberio
    • TiberioRacing
« Reply #4 on: September 22, 2021, 03:58:47 PM »
UGH
Online sdcr
« Reply #5 on: September 22, 2021, 04:29:26 PM »
Might be different on the Le Mans 4, but on my 1983 Le Mans III, I recall just separating the carrier, from the swing arm pin, and suspending it.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #6 on: September 22, 2021, 04:44:42 PM »
That will clear the caliper from disc & then line up carrier w/large cut-out on disc like the rest. I use the allens w/kind of a ball on end.
Offline nc43bsa
« Reply #7 on: September 22, 2021, 05:18:29 PM »
Jeez, Mike, I would have thought you would have done this at least a few dozen times over the decades!   :evil:
1990 MilleGT
« Reply #8 on: September 22, 2021, 05:22:58 PM »
He has a pit crew.   :shocked: :shocked: :shocked:   :grin:
Offline mtiberio
    • TiberioRacing
« Reply #9 on: September 22, 2021, 05:58:14 PM »
Never have I pulled a rear wheel on a LM4. First time I have ever owned one. Had a LM3, which is same as T-3 tech.
« Reply #10 on: September 22, 2021, 06:03:41 PM »
Shouldn't be that hard.  Just make sure the rear of the bike is higher for clearance to take the wheel & tire out.  2x6 under the center stand then a small 2x4 under each foot.  No need for a lift but if you have one, even better.
I usually remove the caliper off the bracket.  Shouldn't be that hard.   :thumb:
Offline nc43bsa
« Reply #11 on: September 22, 2021, 06:11:44 PM »
I know of several guys who take the rear drive off their Tontis when they take the wheel off.
Then it's a trivial matter to grease the drive shaft splines at the same time.
1990 MilleGT
Offline Scout63
« Reply #12 on: September 22, 2021, 11:05:51 PM »
If it’s the same as a wire wheeled Tonti, I do unbolt the caliper and zip tie it up to the frame.  The removable panel in the cheap lift tables is handy. +1 on unbolting the bevel box.  It gives you a chance to grease the drive shaft as well.
Ben Zehnder - Orleans, MA USA
Offline guzzista
« Reply #13 on: September 23, 2021, 12:27:24 AM »
IMO some rear wheels as in Cali3/ 1100, EV and, as    Mike reports  the LM4 , it may  just be  easier to separate the caliper from the bracket than to try finagling the wheel off with bot items bolted to each other. YMMV
Offline mtiberio
    • TiberioRacing
« Reply #14 on: September 23, 2021, 04:11:00 AM »
My Lemans 4 is undergoing a race bike conversion (land speed racer). There is no fender behind the saddle/frame. Pulling the wheel straight back is no issue. I regularly pull the rear drives to change gearing, etc, so grease is not an issue. Currently I'm running a 110/90-18 rear tire (narrower/smaller diameter than the stock 130/80) on the 3" rear rim. Getting it out is not an issue. I also run short shocks to lower the bike, so the tire is already pretty high in the air when on the center stand (which will be removed for racing). Of course removing the 2 bolts holding the caliper on is easy, I just prefer to be able to pull the rear wheel with only having to take off the axle nut and loosening the pinch. Spoiled I guess...
« Reply #15 on: September 23, 2021, 06:41:03 AM »
I used to like watching your races... :sad:
Offline guzziart
« Reply #16 on: September 23, 2021, 07:43:18 AM »
 :thumb:  Yep, every rear tire change but not because of caliper or mount bracket interference with wheel removal, I just do it to grease splines.
