Author Topic: Need new motor and transmission  (Read 1708 times)
Online Ariel
« on: September 23, 2021, 10:26:24 PM »
Hi
I'm looking for a good used 1100 motor/clutch/gearbox unit, preferably 1100, low milage.
Searching Ebay, I found a few motors and other parts from "pinwall_cycle_parts".
I sent them a message, but no answer yet.
I live in Israel, and I prefer buying from the USA, prices are better than Europe.
Are any other vendors that have used guzzi parts?
Thanks,
Ariel
Re: Need new motor and transmission
« Reply #1 on: September 24, 2021, 04:56:26 AM »
Welcome to the forum Ariel, i'm sure you will get lots of suggestions soon.
It might be cheaper to buy a complete bike that way you would have a better idea of the milage.
« Reply #2 on: September 24, 2021, 07:52:14 AM »
If I lived that far away I wouldn't deal with pinwheel. They don't seem to know much about which Guzzi they have and are not very good at comunicating.
« Reply #3 on: September 24, 2021, 07:53:56 AM »
What is wrong with your engine/transmission?
Online John A
« Reply #4 on: September 24, 2021, 10:44:24 AM »
I agree. For instance they separate the rear drive and pinion assembly and try to sell them separately. I contacted them and told them they were making both worthless as they need to stay together. I asked if they would then check the serial numbers on the crown wheel and pinion so I could buy a matching set. They couldn’t comprehend that and continued to make those parts junk and trying to sell them to the unaware.
Offline skippy
« Reply #5 on: September 24, 2021, 10:59:33 AM »
You should specify exactly which 1100/transmission combo you are looking for. 1100/5-speed, 1100/6-speed?
Skippy
23 V100 Mandello
20 V85TT
Online Ariel
« Reply #6 on: September 24, 2021, 09:41:22 PM »
The engine is fine, some leaks, some noise from the valve gear, but nothing horrible.
My bike is a 1983 G5 with 1994 1000 engine (digiplex).
The gearbox and clutch are the main issue, both are worn.
I want to replace both, and upgrade the engine.
Online Ariel
« Reply #7 on: September 24, 2021, 09:42:43 PM »
Skippy
1100/ 5 speed, for tonti frame.
Online Ariel
« Reply #8 on: September 24, 2021, 09:45:38 PM »
Maybe, but the problem is that I can't import to Israel a whole bike, unless is 30 years old or older, due to Import regulations (or brand new).
