Author Topic: rear drive parts Cal II  (Read 1201 times)
Offline Petrus Rocks
« on: September 27, 2021, 10:18:21 AM »
I installed a new cardan joint,  bearing, and shaft coupler.  Upon inspection the pinion gear is spalling.  Looking for a used rear end in good shape or suggestions about where I can find a trustworthy source for the gear and ring.  Stein Dinse is the cheapest for a new set but I might also need the bearings and shims.  Also open to someone fixing it for me.
Re: rear drive parts Cal II
« Reply #1 on: September 27, 2021, 10:27:02 AM »
I have a rear drive from a Centauro, I don't know what ratio they had.
« Reply #2 on: September 27, 2021, 03:54:49 PM »
Thanks Foto, I'm told it won't fit.
« Reply #3 on: September 27, 2021, 04:14:06 PM »
Pretty sure it's just the housing mount is a little different?  Just take off that mounting bracket? It is painted different
Not trying to be pushy but the internals could be put into a housing that will work, I even have such a housing.. still don't know the ratio, 8X33?
« Reply #4 on: September 27, 2021, 04:26:08 PM »
8/33. The triangular bracket and cover on the front at the input would need to be removed, plus IIRC the hole in the case for the floating axle pivot bearing is larger as well and a non-floating spacer won't fit.
« Reply #5 on: September 27, 2021, 04:28:04 PM »
Thanks for the clearing that up Charlie.
« Reply #6 on: September 28, 2021, 09:39:03 AM »
Thanks guys, still looking for a 7/33.  That is what I currently have in the bike.
« Reply #8 on: September 28, 2021, 02:59:13 PM »
Sent you PM Petrus Rocks.
