Author Topic: HMB Cams  (Read 8714 times)
Re: HMB Cams
« Reply #60 on: July 28, 2022, 07:30:57 AM »
“I crashed and destroyed my bike but not my motor, but decided not to transplant my motor into a donor bike because the "intakes were not blended". Manfred pulled me aside and told me, "here is a secret, it is not that important", which would agree with what Rough Edge said. Why wouldn't this be common knowledge? Manfred made a bunch of $ porting heads for people.“
I never had the heads on my CX ported when it went from 30’s to 36mm carbs, and it’s always run perfectly fine and it’s been that way for at least 10 plus years and now that it needs a valve job I’m not going to bother with that expense of porting the heads.
Offline Kredge75
Re: HMB Cams
« Reply #61 on: July 28, 2022, 09:47:47 AM »
...Does that sum it up?
Yes! Thanks for taking the time.
After talking to Mark @ Guzzi Classics and riding my 850T around Monterey during the last AHRMA races I'm realizing maybe hot rodding the engine isn't necessary- they have so much character.
Still fiddling with different carbs, though.
1975 850T
czakky82
Re: HMB Cams
« Reply #62 on: July 28, 2022, 07:47:31 PM »
I will say that a lightened flywheel is nice, if only for the better shifting. It’s kind of a detractor from the guzzi thing though…
Offline Kredge75
Re: HMB Cams
« Reply #63 on: July 29, 2022, 05:34:13 PM »
When I had my gearbox off to fix a leak I actually put a Le Mans flywheel in. All that work, I had to at least make that change.
1975 850T
