Author Topic: How to identify Final Drive Ratio...?  (Read 2956 times)
Offline radguzzi
« on: October 26, 2021, 12:40:51 PM »
I have a surplus Tonti Final Drive unit that I would like to sell and need to be able to identify what the ratio is.  How does one go about doing that...?  From the outside...
The only marks on the castings are Part Numbers so I am guessing that is not going to be a help.  The only other number is a number "11" stamped into the bearing hub.
I would venture a guess that it is the more common 8/33 however, I honestly do not know.
Any ideas folks...?
Thanks,
Rob
Current:
2004 EV Touring
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
A VeeDub and an MGB...
The Journey is the Reward
Online Bob Wegman
Re: How to identify Final Drive Ratio...?
« Reply #1 on: October 26, 2021, 12:55:01 PM »
How about rotating the pinion and counting the revolutions needed to rotate the wheel hub gear a complete revolution.
MGNOC # 20848
AMA# 548668
Offline mtiberio
    • TiberioRacing
« Reply #2 on: October 26, 2021, 02:10:22 PM »
first principles
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #3 on: October 26, 2021, 02:33:06 PM »
Or pull the pinion carrier out of the case and count the number of teeth on the pinion gear. You'll want to inspect the teeth for damage anyway (and take photos for any prospective buyers).
Offline Petrus Rocks
« Reply #4 on: October 26, 2021, 03:36:10 PM »
What Charlie said.  It's off a V11, correct?
Offline radguzzi
« Reply #5 on: October 26, 2021, 05:07:44 PM »
Ok, I count nine (9)teeth... There is an inscription on the end of the pinion "392"  What is all this telling me Charlie...?
I do not see any indication of abnormal wear on the gear teeth.
Thanks,
Rob
I don't believe so, I'm thinking an 80's vintage LeMans, CX or SP... just a guess though.
rad__
« Last Edit: October 26, 2021, 06:06:27 PM by radguzzi »
Current:
2004 EV Touring
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
« Reply #6 on: October 26, 2021, 06:07:58 PM »
That's a Convert rear drive. Small splines & 9/34 teeth.
« Last Edit: October 26, 2021, 06:09:26 PM by guzzisteve »
Offline TOMB
« Reply #7 on: October 26, 2021, 07:06:57 PM »
If the pinion has 20 teeth on the front part of the shaft 9 teeth ib the pinion  and 34 teeth on the ring its  for a convert
Pinion 9 teeth
Ring 34 teeth
Final ratio is 3.777
The 392 #on the pinion  will match the same # on the ring so you know that the ring and pinion are a match set
It's a high ratio final drive but the torque converter and the internal gears in the transmission make it work.
TOMB
« Last Edit: October 26, 2021, 07:13:26 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #8 on: October 26, 2021, 07:21:05 PM »
Spare rear drive for your Convert!
Offline radguzzi
« Reply #9 on: October 26, 2021, 08:10:34 PM »
Pinion 9 teeth
Ring 34 teeth
TOMB
It is indeed the numbers that you both mention.
I may just reconsider and keep it for my own Convert.  Ya never know when you might need a final drive... hope not but if it left, guess what would happen..! ?!
Great information, you guys are great, thanks.
Current:
2004 EV Touring
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
Offline TOMB
« Reply #10 on: October 28, 2021, 08:17:54 AM »
Just a follow-up it was also a special differential ring and pinion for the Cal 11 convert that had six teeth on the pinion 20 teeth on the spline the coupler from the spline to the drive shaft was a 20 on one end to 10 on the other I don't remember what the ring  teeth count but it was a special gear set just for the convert Cal 11 probably would work on it earlier convert if anybody has any other information please add it
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
