Author Topic: NGC dumb tractor question  (Read 970 times)
« on: November 11, 2021, 05:42:24 PM »
Why do these rims attach like they do, is there a mechanical reason?
Offline cliffrod
Re: NGC dumb tractor question
« Reply #1 on: November 11, 2021, 05:52:42 PM »
You can attach the rim to the hub at different points to widen or narrow the rear track.  Most of the time, people just attach them at the widest position for greatest stability.  But in some situations, it's advantageous to narrow the rear track to fit between rows or in certain areas like a barn where you may be cleaning manure or ??
« Reply #2 on: November 11, 2021, 05:53:02 PM »
It’s to adjust the wheel track width so you don’t squash the tomatoes. Did you get a new tractor?
« Reply #3 on: November 11, 2021, 07:43:01 PM »
Ahah I knew there must have been a reason and you guys were the perfect ones to ask..
No I didn't get a new tractor, we have a bobcat that does most of what we need.
« Last Edit: November 11, 2021, 07:54:11 PM by fotoguzzi »
Offline tris
« Reply #4 on: November 12, 2021, 05:10:56 AM »
Did the 4x2 get it out or was divine intervention needed :grin:
1993 TW125 "POS" - Resting
« Reply #5 on: November 12, 2021, 07:14:24 AM »
We pulled it out with a 1997 Ford Explorer and a long chain.
Offline Alfetta
« Reply #6 on: November 12, 2021, 07:43:16 AM »
you will also notice that the rim has an angles rib the the wheel clamps to.  This is done so that the moving of the rim in an out can be accomplished using the tractor drive. (no need to jack the wheel up and slid it on the axle.
