Author Topic: Convert Courtesy Light?  (Read 1404 times)
« on: November 14, 2021, 04:21:04 AM »
There's a light switch on the dash feeding about 8 inches of two conductor wire ending in female bullet connectors.
If anyone has a complete Convert could you describe what the light looks like and where it mounts.
I'm just curious as to what this light looked like, if I replace it at all I will use an LED
There's also a pair of wires under the tank RH side and a Low Fuel lamp on the dash but my bike doesn't have a switch in the tank or a spot for one, I wonder if someone swapped the tank out or it was discontinued?
Mine is a 76, she's a bit dirty from riding in the rain.
« Last Edit: November 14, 2021, 04:39:25 AM by Kiwi_Roy »
Offline TOMB
Re: Convert Courtesy Light?
« Reply #1 on: November 14, 2021, 06:31:14 AM »
The switch is there for whatever you want to use it forI have a complete 76 Convert that switches in the upper right corner excuse me lower right corner on my convert and it doesn't do anything the wires are just hanging into breeze it's a gift from the factory usually for whatever you want But may I suggest if you're gonna run power through it use a relay Other than that it can just hang there and do nothing like mine is doing
TOMB
« Last Edit: November 14, 2021, 06:31:56 AM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #2 on: November 14, 2021, 08:35:49 AM »
I have that switch hooked up to my Kuryakyn battery gauge and GPS. I think it may have originally powered a light for a police officer to write a ticket by.
Sounds like someone has swapped your tank for a T or T3 one.
« Reply #3 on: November 14, 2021, 01:16:38 PM »
That makes sense, so mine never terminated in a light, I will have to have one now so I can tell that story LOL
I wonder why they would have swapped it out?
TOMB
Thanks for your response, so i'm not missing anything then.
I once had a VB Ariel with a hand inspection lamp, a little brass lamp fitting in the in-tank dash.
« Last Edit: November 14, 2021, 01:21:15 PM by Kiwi_Roy »
