Author Topic: How to Remove Ignition Switch 2014 California  (Read 2117 times)
Offline EDWARDDOSKEY
« on: November 16, 2021, 01:44:12 PM »
I need to remove the ignition switch but can't figure out how to remove the security plug/pin that's on the left side of the mounting bracket in place of a bolt. I already tried drilling it out, but won't come off and I'm afraid I might damage something if I keep drilling.
Any suggestions?
Offline Utrider
Re: How to Remove Ignition Switch 2014 California
« Reply #1 on: November 16, 2021, 04:30:21 PM »
I just grabbed it with vise grips on the flat.
You have the switch go out on yours too?
« Reply #2 on: November 16, 2021, 08:11:44 PM »
Thanks. I tried that but this bugger is stuck in there good!
« Reply #3 on: November 16, 2021, 11:42:58 PM »
Why are you trying to remove the switch?
I sent you a PM
Offline Utrider
« Reply #4 on: November 17, 2021, 10:23:51 AM »
Maybe try a little bit of heat.  Mine went out on me about 800 miles away from home.  We found if we twisted it to the on position VERY slowly we could find a spot where it would be on.  I would just keep the key in that spot and made it all the way home.  I found one on Ebay and just swapped out the bottom as was mentioned in the other thread. Then you don't have to worry about the key and the security system.
« Reply #5 on: November 27, 2021, 05:58:51 PM »
Thanks. Heat is definitely what it needed.
