Author Topic: Should MGTC be calibrated after a suspension upgrade?  (Read 1964 times)
Offline agdrache
« on: December 05, 2021, 01:14:31 PM »
I know that the traction control on my V7 III should be calibrated for new tires, but should it also be done when suspension components are upgraded?
2018 MG V7 III Stone
2011 Suzuki TU250X
Re: Should MGTC be calibrated after a suspension upgrade?
« Reply #1 on: December 05, 2021, 02:20:35 PM »
I would think not, but would like to hear why anyone would think otherwise.
Is it just an on board setup like the V85 ?
Offline agdrache
« Reply #2 on: December 06, 2021, 10:17:02 PM »
My thinking was basically that since the main job of suspension is to keep the tire in touch with the ground, a significant change in suspension might affect the amount of traction the tires can get and impact how the traction control works....but reading through the calibration process, it seems like it just needs to calculate the relative speed of the wheels at a known speed
2011 Suzuki TU250X
« Reply #3 on: December 06, 2021, 10:44:40 PM »
I don't believe that's necessary, I put a larger than normal back tire on mine that made the speedo error drop from 10% high to almost 0 and didn't notice anything. On the other hand I did have the traction control cutting in one day under acceleration. To my surprise i found the rear tire was very low in air pressure, about 15 PSI so traction control is quite sensitive.
Offline Tusayan
« Reply #4 on: December 07, 2021, 10:19:03 AM »
Every time I see this thread I think of this…  :grin: which could surely use a suspension upgrade but definitely would not need any electronics calibration.
« Last Edit: December 07, 2021, 10:25:25 AM by Tusayan »
Offline chrisfer
« Reply #5 on: December 07, 2021, 10:29:28 AM »
No need to calibrate. With upgrade rear suspension (EMC) my MGTC is setting in position 2 with no more intrusion.
« Last Edit: December 07, 2021, 10:30:06 AM by chrisfer »
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
