Author Topic: Tonti swing arm pivot insert sleeve  (Read 1177 times)
Offline Klinkhammer
  • 2024 Board Donor
« on: December 11, 2021, 10:02:38 AM »
As I removed the left side pivot bearing race from the swing on my 1976 Convert an insert sleeve came out of the swing arm with the race still in it. Haven't seen this before (haven't removed so many pivot bearing races thou...) The insert sleeve can not be seen on any partslist etc.
Will press it back and put a little tack to hold it.
Any thoughts?
« Last Edit: December 11, 2021, 10:21:06 AM by Klinkhammer »
850T Endurance racer lookalike 1974
992 Le Mans III Agostini 1983
V1000 ConverT 1976
850 Le Mans II 1979
BMW R1250GS HP 2019
V7 sport 1972 (Sold)
850T3 California 1977 (Sold)
850T 1974 (Sold)
Re: Tonti swing arm pivot insert sleeve
« Reply #1 on: December 11, 2021, 10:27:49 AM »
It happens to me on occasion, no big deal. I don't tack it or anything else - just remove the bearing, put the "insert" back into the swingarm and then install the bearing. It's not going anywhere.
Offline Klinkhammer
  • 2024 Board Donor
« Reply #2 on: December 11, 2021, 03:02:31 PM »
Good to know! Thanks!
V1000 ConverT 1976
850 Le Mans II 1979
BMW R1250GS HP 2019
850T 1974 (Sold)
Online nc43bsa
« Reply #3 on: December 11, 2021, 03:56:45 PM »
I haven't seen one of these inserts come out, either.
Does it have a step for the tapered bearing race to seat on?
1990 MilleGT
« Reply #4 on: December 11, 2021, 04:08:14 PM »
Yes, there's a flange on the outside to stop it from going into the swingarm too deep and another flange on the inside to stop the outer race of the tapered roller bearing.
